土木在线论坛 \ 施工技术 \ 工程测量 \ 计算是测量技能之笔,仪器应用是测量技能之眼
发布于:2009-04-26 16:11:26 来自:施工技术/工程测量 [复制转发]
我觉计算应放在测量的第一位,计算一天学不会,而用仪器最多一天可搞定,所以我们多专研测量计算,那么CISAO计算编程也是首当其冲的必要工作,现我把我的5800测量线路计算程序与大家分享一下
正算程序
01---“ZB”
"K="?K:"B="?Q
6→N: Prog“SJK-PM”:
Lbl 1
Prog“YS-PM”
Z[6N]-Z[6] →C
IF K>C+L+Z[8]+M Then N+1→N:Goto 1:IfEnd
Lbl 2
K≤C=>Goto 3⊿
K≤C+L=>Coto 4⊿
If K≤C+L+Z[8] Then Goto 5:IfEnd :Goto 6⊿
Lbl 3 进入直线段
K-C→S
Z[10]+SCosA→X: Z[11]+SSinA→Y
X+QCos(A+O)→X: Y+QSin(A+O)→Y
Goto Z
Lbl 4 进入一缓段
K-C→S
S-S5/(40(RL)2)+S9/(3456R4L4) →I:1→G:
S3/(6RL)-S7/(336(RL)3)+S11/(42240R5L5) →J
Z[10]+GICosA-JESinA→X
Z[11]+GISinA+JECosA→Y
X+QCos(A+90ES2/(RLπ)+O) →X
Y+QSin(A+90ES2/(RLπ)+O) →Y
Goto Z
Lbl 5 进入圆曲线段
K-C-L→S
90ES/(Rπ)→I: 2Rsin(AbsI) →J
Z[14]+JCos(A+90EL/(Rπ)+I)→X
Z[15]+JSin(A+90EL/(Rπ)+I)→Y
X+Qcos(A+90EL/(Rπ)+180ES/(Rπ)+O)→X
Y+QSin(A+90EL/(Rπ)+180ES/(Rπ)+O)→Y
Goto Z
Lbl 6 进入二缓段
C+L+Z[8]+M-K→S
S∧3/(6RM)-S∧7/(336(RM)∧3)+ S11/(42240R5M5) →J
S-S∧5/(40(RM)∧2) +S9/(3456R4M4):-1→G
Z[12]+GICosB-JESinB→X
Z[13]+GISinB+JECosB→Y
X+QCos(B-90ES∧2/(RMπ)+O) →X
Y+QSin(B-90ES∧2/(RMπ+O) →Y
Goto Z
Lbl Z:
Cls : "K="ocate 3,1,K
"B="ocate 3,2,Q
"X="ocate 3,3,X
"Y="ocate 3,4,Y
“YS-PM”
Lbl 1
Z[6N+3] → L: Z[6N+4] →R: Z[6N+5] →M
Pol(Z[6N+1]-Z[6(N-1)+1],Z[6N+2]-Z[6(N-1)+2])
J→A:A<0=>A+360→A⊿
Pol(Z[6(N+1)+1]-Z[6N+1],Z[6(N+1)+2]-Z[6N+2])
J→B:B<0=>B+360→B: B-A→D
If Sin D≥0 Then 1→E: Else -1→E :IfEnd⊿
If Abs D>180 Then 360-Abs D →D: Else Abs D →D :IfEnd
L/2-L∧3/(240R∧2)+L∧5/(34560R∧4)-L∧7/(8386560R∧6) →Z[2]: 一缓切线增量
M/2-M∧3/(240R∧2)+M∧5/(34560R∧4)-M∧7/(8386560R∧6) →Z[3] 二缓切线增量
L∧2/(24R)-L∧4/(2688R∧3)-L∧6/(506880R∧5) →Z[4]:一缓内移值
M∧2/(24R)-M∧4/(2688R∧3)-M∧6/(506880R∧5) →Z[5] 二缓内移值
Z[2]+(R+Z[5]-(R+Z[4])COS(D)/SIN(D) →Z[6] 一缓切线长
Z[3]+(R+Z[4]-(R+Z[5])COS(D)/SIN(D) →Z[7]二缓切线长
( D-180L*(2Rπ)- 180M*(2Rπ))Rπ/180→Z[8]圆曲线长
Z[6N+1]-Z[6]CosA→Z[10]: Z[6N+2]-Z[6]SinA→Z[11] (ZH点XY坐标)
Z[6N+1]+Z[7]CosB→Z[12]: Z[6N+2]+Z[7]SinB→Z[13] (HZ点XY坐标)
Lbl 2
If L=0: Then Z[10] →Z[14]: Z[11] →Z[15]: Goto 4: IfEnd
L-L∧5/(40(RL)∧2)+ L∧9/(3456(RL)∧4) →I
L∧3/(6RL)-L∧7/(336(RL)∧3) +L∧11/(42240(RL)∧5) →J:
1→G
Z[10]+GICosA-JESinA→Z[14]: Z[11]+GISinA+JECosA→Z[15] (HY点XY坐标)
Lbl A
Z[14]+RCos(A+90EL/(Rπ)+90E) →Z[18] (圆心点X坐标)
Z[15]+RSin(A+90EL/(Rπ)+90E) →Z[19] (圆心点Y坐标)
Lbl 3
If M=0: Then Z[12] →Z[16]: Z[13] →Z[17]: Goto 4: IfEnd
M-M∧5/(40(RM)∧2)+ M∧9/(3456(RM)∧4) →I
M∧3/(6RM)-M∧7/(336(RM)∧3) +M∧11/(42240(RM)∧5) →J:
-1→G
Z[12]+GICosB-JESinB→Z[16]: Z[13]+GISinB+JECosB→Z[17] (YH点XY坐标)
Lbl 4
Return
★“SJK-PM” 平面曲线各交点DJ数据库
O;构筑物与线路交角
Z[6(N-1)]、Z[6(N-1)+1] 、Z[6(N-1)+2] 分别是起点里程、X、Y坐标
Z[6N]、Z[6N+1]、Z[6N+2]、Z[6N+3]、Z[6N+4]、Z[6N+5]分别是各DJ点里程、X、Y坐标、一缓长、半径、二缓长
从N=6(Z[30]…..)开始…….
反算程序
“FQ”
"X="?→X:"Y="?→Y:N=10: Prog“SJK-PM”:
Lbl 1
Prog“YS-PM”
X→I: Y→J: Z[12] →K: Z[13] →Q
Prog“FWJ”
K-B→K:If CosK>0: Then N+1→N:Goto 1:IfEnd
Lbl 2
X→I: Y→J: Z[10] →K: Z[11] →Qrog“FWJ”: K-A→K:If CosK≤0:Then Goto 3:Else Goto 4:IfEnd
Lbl 3进入直线段
X→I: Y→J: Z[10] →K: Z[11] →Q:Prog“FWJ”
K-A→K: ISinK→Q:ICosK→H:Z[6N]-Z[6]+H→K:Goto S
Lbl 4进入HY点切线方位角判定
X→I: Y→J: Z[14] →K:Z[15] →Qrog“FWJ”
K-(A+90EL/(Rπ))→K [ HY点切线方位角A+Ls/(2R)*180/π]
If CosK≤0:Then Goto 5:Else Goto 6:IfEnd
Lbl 5进入一缓段
Prog“HQ”:Goto S
Lbl 6进入YH点切线方位角判定
X→I: Y→J: Z[16] →K:Z[17] →Q:Prog“FWJ”
K-(A+90EL/(Rπ)+180EZ[8]/(Rπ))→K [YH点切线方位角A+90EL/(Rπ)+180EZ[8]/(Rπ)]
If CosK≤0:Then Goto 7:Else Goto 8:IfEnd
Lbl 7进入圆曲线段
Z[14] →I: Z[15] →J: Z[18] →K:Z[19] →Qrog“FWJ”: K→O
X→I: Y→J:Z[18] →K:Z[19] →Qrog“FWJ”:K→P
E(R-I) →Q:Abs(P-O) →K:K>180=>360-K→K
Z[6N]-Z[6]+L+RπAbsK/180→K:Goto S
Lbl 8
Prog“QH”:Goto S
Lbl S: Cls : "X="ocate 3,1,X
"Y="ocate 3,2,Y 显示ZH点X坐标
"K="ocate 3,3,K 显示ZH点Y坐标
"B="ocate 3,4,Q
“FWJ” Pol(I-K,J-Q)
K=J:K<0=>K=K+360
“HQ”
I=X:J=Y:K=Z[10]:Q=Z[11]
Prog“FWJ”
P=K:K=P-A:H=ICosAbsK
I=(L-(L-L∧3/(40R∧2)))÷(L-L∧3/(40R∧2))∧5×H∧5
H=H+AbsI:V=30H∧2/(RLπ):J=(H-H∧5/(40(RL)∧2))/CosV
Pol(Z[10]+Cos(A+VE)J -X, Z[11]+JSin(A+VE)-Y)
G=P-(A+VE):SinG>0=>G=1:≠>G=-1⊿
Z=H+(AbsI)Sin3V GE:Z=90Z∧2/(RLπ):
Z=H+(AbsI)SinZ GE:W=90Z∧2/(RLπ):F=(AbsI)SinW
S=Ftan(Abs(W-3V)÷3×2)=(AbsI)CosW
U=F÷Cos(Abs(W-3V)÷3×2)=Q+SGE
K=Z[6N]-Z[6]+(H+UGE)=QG
Lbl S
“QH”I=X:J=Y:K=Z[12]=Z[13]
Prog“FWJ”
P=K:K=P-(B+180):H=ICosAbsK
I=(M-(M-M∧3/(40R∧2)))/(M-M∧3/(40R∧2))∧5×H∧5
H=H+AbsI:V=30H∧2/(RMπ):J=(H-H∧5/(40(RM)∧2))/CosV
Pol(X-( Z[12]+Jcos(B+180-VE)),Y-( Z[13]+JSin(B+180-VE))):
G=P-(B+180-VE):SinG>0=>G=-1:≠>G=1⊿
Z=H+(AbsI)Sin3V GE:Z=90Z∧2/(RMπ):Z=H+(AbsI)SinZ GE:W=90Z∧2/(RMπ):F=(AbsI)SinW
U=F÷Cos(Abs(W-3V)÷3×2):Q=Q+SGE
K=Z[6N]-Z[6]+L+Z[8]+M-(H+UGE):Q=QG:
Lbl S
 要素计算
02-“YSJS”
50→DimZ "DUANG="?N:5+N→N rog“SJK-PM”:区段选择后调用数据库文件计算可直接修改输入
Z[6(N-1)+1]→A 起点N坐标
Z[6(N-1)+2]→B 起点E坐标
Z[6N]→K 交点DJ点里程
Z[6N+1]→X 交点DJ点X坐标
Z[6N+2]→Y 交点DJ点Y坐标
Z[6N+3]→L  一缓长
Z[6N+4]→R  半径
Z[6N+5]→M
Z[6(N+1)+1]→W 下交点DJ点(终点)X坐标
Z[6(N+1)+2]→V 下交点DJ点(终点)Y坐标
Lbl 1
"ZD1-X="?A:A→Z[6(N-1)+1]:"ZD1-Y="?B:B→ Z[6(N-1)+2]
"JD-K="?K : K→Z[6N]:"JD-X="?X:X→Z[6N+1]:"JD-Y="?Y: Y→Z[6N+2]
"LS1="?L : L→Z[6N+3]:"R="?R:R→Z[6N+4]:"LS2="?M: M→Z[6N+5]
"ZD2-X="?W:W→Z[6(N+1)+1]:"ZD2-Y="?V:V→ Z[6(N+1)+2]
Lbl 2
Prog“YS-PM”
Lbl 3
Cls : "a="ocate 3,1,ED 显示转角
"T="ocate 3,2,Z[6] 显示切线长
"LC=":Locate 4,3,Z[8] 显示圆曲线长
"E=":Locate 3,4,(R+Z[4])/ Cos(D/2)-R⊿ 显示外距长
Lbl 4
Cls : "ZH-K=":Locate 6,1,Z[6N]-Z[6] 显示ZH点里程
"ZH-X=":Locate 6,2,Z[10] 显示ZH点X坐标
"ZH-Y=":Locate 6,3,Z[11] 显示ZH点Y坐标
"ZH-Fa=":Locate 7,4,A⊿ 显示ZH点切线方位角
Lbl 5
Cls : "HY-K=":Locate 6,1,Z[6N]-Z[6]+L 显示HY点里程
"HY-X=":Locate 6,2,Z[14] 显示HY点X坐标
"HY-Y=":Locate 6,3,Z[15] 显示HY点Y坐标
"HY-Fa=":Locate 7,4,A+E180L/(2Rπ)⊿ 显示HY点切线方位角
Lbl 6
Cls : "YH-K=":Locate 6,1,Z[6N]-Z[6]+L+Z[8] 显示YH点里程
"YH-X=":Locate 6,2,Z[16] 显示YH点X坐标
"YH-Y=":Locate 6,3,Z[17] 显示YH点Y坐标
"YH-Fa=":Locate 7,4,A+E180L/(2Rπ)+ E180Z[8]/(Rπ)⊿ 显示HY点切线方位角
Lbl 7
Cls : "HZ-K=":Locate 6,1,Z[6N]-Z[6]+2L+Z[8] 显示HZ点里程
"HZ-X=":Locate 6,2,Z[12] 显示HZ点X坐标
"HZ-Y=":Locate 6,3,Z[13] 显示HZ点Y坐标
"HZ-Fa=":Locate 7,4,B 显示HZ点切线方位角
[ 本帖最后由 y01h02f03 于 2009-5-14 11:08 编辑 ]
全部回复(7 )
  • txch7802
    txch7802 沙发
    楼主辛苦了!!!
    2009-07-02 22:01:02
  • zxeti002
    zxeti002 板凳
    是不是传个实例
    这样大家会理解的更明白哈
    2009-05-08 22:16:08
工程测量
7.08 万条内容 · 314 人订阅
求测绘坐标正算反算公式
:'( 急啊 请朋友们帮忙谢谢大家了 正算反算公式
