土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 砼梁侧面垂直裂缝
砼梁侧面垂直裂缝
发布于:2009-04-21 09:53:21 来自:建筑结构/混凝土结构 [复制转发]
有一幢六层陶瓷厂房,主体完工后3个月,发现主梁和次梁的中间部位梁侧面有0.5mm垂直裂缝的(梁底没有)。有哪位高手指点一下是什么原因,将有积分相送。
  • snake_dingo
    snake_dingo 沙发
    不知道楼主所说的主梁和次梁高度是多少?个人认为应该是梁侧筋配筋不足的原因,但也不能排除其他的原因,建议具体详查
    2009-04-21 10:34:21
140.17 万条内容 · 2228 人订阅
碳纤维布加固钢筋混凝土T型截面梁正截面抗弯承载力计算
论文简介: Abstract: An analytical method for T-section R.C. beams strengthened with externally bonded carbon fiber reinforced plastic (CFRP) sheets was proposed according to different failure modes. At the same time, the effective strain of CFRP was advanced. Finally, the author put forward designed formulae based on the design code.
