土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 碳纤维布加固钢筋混凝土T型截面梁正截面抗弯承载力计算
发布于:2009-04-21 09:30:21 来自:建筑结构/混凝土结构 [复制转发]
论文简介:
Abstract: An analytical method for T-section R.C. beams strengthened with externally bonded carbon fiber reinforced plastic (CFRP) sheets was proposed according to different failure modes. At the same time, the effective strain of CFRP was advanced. Finally, the author put forward designed formulae based on the design code.
Keywords: CFRP;strengthening;T-section R.C. beams;flexural capacity
使用不当、钢筋腐蚀、设计或施工错误都会造成钢筋混凝土构件的刚度、抗弯承载力不足或裂缝开展过宽而需要补强、加固。碳纤维纤维复合物(CFRP)由于其自身的优点,如强度高、重量低、易于施工、耐腐蚀等[1、2],近年来在我国的应用逐渐增多。本文基于《公路钢筋混凝土及预应力混凝土桥涵设计规范(JTG D62)》[3](以下简称《公路桥规》),给出了钢筋混凝土T型截面梁抗弯承载力计算公式及工程实用设计公式。
1 正截面抗弯承载力计算
1.1 基本假定
⑴平截面假定。
⑵不考虑混凝土的抗拉强度。
附件名:20094211240277416839.zip
文件大小:404K
(升级VIP 如何赚取土木币)
  • lrg005
    lrg005 沙发
    谢谢楼主,好资料,学习了!
    2015-08-07 09:53:07
  • wanda8458
    wanda8458 板凳
    本版新规定:为了防止链接失效,导致其他网友看到此贴而无法下载,禁止新帖以一个连接加一句话完事。必须上传附件!
    详情见置顶帖的相关告示。
    从4.12日起发此类贴都将扣除5分,以示惩戒!:handshake
    2009-04-21 22:59:21
140.17 万条内容 · 2228 人订阅
论文简介: Abstract: An analytical method for T-section R.C. beams strengthened with externally bonded carbon fiber reinforced plastic (CFRP) sheets was proposed according to different failure modes. At the same time, the effective strain of CFRP was advanced. Finally, the author put forward designed formulae based on the design code.
