土木在线论坛 \ 道路桥梁 \ 铁路工程 \ 软土地基上分期施工的路堤沉降预测方法(英文文献及译文)
发布于:2009-03-02 00:45:02 来自:道路桥梁/铁路工程 [复制转发]
朊土地基上分期施工的路堤沉降预测方法(中英文对照版)
DOC格式 WORD文档
大小: 125KB
注:无需解压密码
朊土地基上分期施工的路堤沉降预测方法
摘要:沉降量和沉降速率控制是软土地基上路堤工程设计的关键问题,由于固结理论的局限性和参数的不确定性,理论预测的精度较低,而基于现场实测数据的观测法则显示出了较高的精度。本文在Asaoka观测法的基础上,形成了一种软土路基上分期施工时路堤沉降预测的方法,结合江苏海相软土上的高速公路工程进行了沉降预测分析。
关键词:沉降, 路堤, 观测法, 分期施工, 江苏海相软土
Settlement prediction of embankment s with stage
construction on soft ground
LIU Song-yu(Institute of Geotechnical Engineering, Southeast University,Nanjing 210096,China)
JING Fei(Institute of Geotechnical Engineering, Southeast University,Nanjing 210096,China)
Abstract: The magnitude and rate of the settlement are the key elements subjected to design analysis of embankments on soft ground. The observational
Institute of Geotechnical Engineering,Southeast University,Nanjing210096,China
methods based onfield measurement have indicated the promising results and become effective methods to predict the final settlement, while the uncertainties of parameters and theories limit significantly the accuracy of settlement estimation. This paper presents an observational method to predict the settlement performance of embankments with stage construction on soft ground based on Asaoka method. The case studies show the accordance of the predicting results with the field measured data. It is also given from the case study that the value of Eu / Cu ratio ranges from 50 to 100 for Jiangsu Marine clay and its actual coefficient of consolidation is almost one order of magnitude larger than the laboratory data.
Key words: settlement, embankment, observational method, stage construction, Jiangsu Marine clay
全部回复(17 )
  • giveyoulife
    giveyoulife 沙发
    下了支持下楼主
    2011-04-17 11:01:17
  • wxf_wh
    wxf_wh 板凳
    very good
    2011-03-29 11:20:29
铁路工程
6.76 万条内容 · 134 人订阅
★养老保险、落户、子女入学——都有用的职业资格
——就业与保障,和您的切身利益相关经报省劳动厅、省民政厅批准,我校面向企业中、高层管理人员进行高级经营师、高级策划师、技师、高级技师职业资格评审工作。评审合格统一颁发高级国家职业资格证书(相当于中、高级工程师职称,并按国家有关规定在社保、落户、子女入学及福利上享受同等待遇),证书统一编号管理和网上查询。根据《省人民政府文件( [2002]37号)、《省劳动和社会保障厅文件(劳社办[2002]226号)》、《省建设厅、省劳动和社会保障厅文件(建[2002]90号)》、《省劳动厅文件(劳[1999]038号)》等文件精神:取得高级经营师、高级策划师职业资格人员享受补充医疗保险、养老保险及职务津贴等政策。
