土木在线论坛 \ 给排水工程 \ 建筑消防给水 \ NFPA规范 目录集
NFPA规范 目录集
发布于:2009-02-24 10:14:24 来自:给排水工程/建筑消防给水 [复制转发]
NFPA 1 Fire Code
NFPA 2 Hydrogen Technologies Code
NFPA 3 Standard for the Commissioning and Integrated Testing of Fire Protection and Life Safety Systems
NFPA 10 Standard for Portable Fire Extinguishers
NFPA 11 Standard for Low-, Medium-, and High-Expansion Foam
NFPA 12 Standard on Carbon Dioxide Extinguishing Systems
NFPA 12A Standard on Halon 1301 Fire Extinguishing Systems
NFPA 13 Standard for the Installation of Sprinkler Systems
NFPA 13D Standard for the Installation of Sprinkler Systems in One- and Two-Family Dwellings and Manufactured Homes
NFPA 13E Recommended Practice for Fire Department Operations in Properties Protected by Sprinkler and Standpipe Systems
NFPA 13R Standard for the Installation of Sprinkler Systems in Residential Occupancies up to and Including Four Stories in Height
NFPA 14 Standard for the Installation of Standpipes and Hose Systems
NFPA 15 Standard for Water Spray Fixed Systems for Fire Protection
NFPA 16 Standard for the Installation of Foam-Water Sprinkler and Foam-Water Spray Systems
NFPA 17 Standard for Dry Chemical Extinguishing Systems
NFPA 17A Standard for Wet Chemical Extinguishing Systems
NFPA 18 Standard on Wetting Agents
NFPA 18A Standard on Water Additives for Fire Control and Vapor Mitigation
NFPA 20 Standard for the Installation of Stationary Pumps for Fire Protection
NFPA 22 Standard for Water Tanks for Private Fire Protection
NFPA 24 Standard for the Installation of Private Fire Service Mains and Their Appurtenances
NFPA 25 Standard for the Inspection, Testing, and Maintenance of Water-Based Fire Protection Systems
NFPA 30 Flammable and Combustible Liquids Code
NFPA 30A Code for Motor Fuel Dispensing Facilities and Repair Garages
NFPA 30B Code for the Manufacture and Storage of Aerosol Products
NFPA 31 Standard for the Installation of Oil-Burning Equipment
NFPA 32 Standard for Drycleaning Plants
NFPA 33 Standard for Spray Application Using Flammable or Combustible Materials
NFPA 34 Standard for Dipping and Coating Processes Using Flammable or Combustible Liquids
NFPA 35 Standard for the Manufacture of Organic Coatings
NFPA 36 Standard for Solvent Extraction Plants
NFPA 37 Standard for the Installation and Use of Stationary Combustion Engines and Gas Turbines
NFPA 40 Standard for the Storage and Handling of Cellulose Nitrate Film
NFPA 45 Standard on Fire Protection for Laboratories Using Chemicals
NFPA 51 Standard for the Design and Installation of Oxygen-Fuel Gas Systems for Welding, Cutting, and Allied Processes
NFPA 51A Standard for Acetylene Cylinder Charging Plants
NFPA 51B Standard for Fire Prevention During Welding, Cutting, and Other Hot Work
NFPA 52 Vehicular Fuel Systems Code
NFPA 53 Recommended Practice on Materials, Equipment, and Systems Used in Oxygen-Enriched Atmospheres
NFPA 54 National Fuel Gas Code
NFPA 55 Standard for the Storage, Use, and Handling of Compressed Gases and Cryogenic Fluids in Portable and Stationary Containers, Cylinders, and Tanks
NFPA 58 Liquefied Petroleum Gas Code
NFPA 59 Utility LP-Gas Plant Code
NFPA 59A Standard for the Production, Storage, and Handling of Liquefied Natural Gas (LNG)
NFPA 61 Standard for the Prevention of Fires and Dust Explosions in Agricultural and Food Processing Facilities
NFPA 68 Standard on Explosion Protection by Deflagration Venting
NFPA 69 Standard on Explosion Prevention Systems
NFPA 70 National Electrical Code?
NFPA 70A National Electrical Code? Requirements for One- and Two-Family Dwellings
NFPA 70B Recommended Practice for Electrical Equipment Maintenance
NFPA 70E Standard for Electrical Safety in the Workplace?
NFPA 72 National Fire Alarm Code?
NFPA 73 Electrical Inspection Code for Existing Dwellings
NFPA 75 Standard for the Protection of Information Technology Equipment
NFPA 76 Standard for the Fire Protection of Telecommunications Facilities
NFPA 77 Recommended Practice on Static Electricity
NFPA 79 Electrical Standard for Industrial Machinery
NFPA 80 Standard for Fire Doors and Other Opening Protectives
NFPA 80A Recommended Practice for Protection of Buildings from Exterior Fire Exposures
NFPA 82 Standard on Incinerators and Waste and Linen Handling Systems and Equipment
NFPA 85 Boiler and Combustion Systems Hazards Code
NFPA 86 Standard for Ovens and Furnaces
NFPA 87 Recommended Practice for Fluid Heaters
NFPA 88A Standard for Parking Structures
NFPA 90A Standard for the Installation of Air-Conditioning and Ventilating Systems
NFPA 90B Standard for the Installation of Warm Air Heating and Air-Conditioning Systems
NFPA 91 Standard for Exhaust Systems for Air Conveying of Vapors, Gases, Mists, and Noncombustible Particulate Solids
NFPA 92A Standard for Smoke-Control Systems Utilizing Barriers and Pressure Differences
NFPA 92B Standard for Smoke Management Systems in Malls, Atria, and Large Spaces
NFPA 96 Standard for Ventilation Control and Fire Protection of Commercial Cooking Operations
NFPA 99 Standard for Health Care Facilities
NFPA 99B Standard for Hypobaric Facilities
NFPA 99C Standard on Gas and Vacuum Systems
NFPA 101 Life Safety Code?
NFPA 101A Guide on Alternative Approaches to Life Safety
NFPA 102 Standard for Grandstands, Folding and Telescopic Seating, Tents, and Membrane Structures
NFPA 105 Standard for the Installation of Smoke Door Assemblies and Other Opening Protectives
NFPA 110 Standard for Emergency and Standby Power Systems
NFPA 111 Standard on Stored Electrical Energy Emergency and Standby Power Systems
NFPA 115 Standard for Laser Fire Protection
NFPA 120 Standard for Fire Prevention and Control in Coal Mines
NFPA 122 Standard for Fire Prevention and Control in Metal/Nonmetal Mining and Metal Mineral Processing Facilities
NFPA 130 Standard for Fixed Guideway Transit and Passenger Rail Systems
NFPA 140 Standard on Motion Picture and Television Production Studio Soundstages, Approved Production Facilities, and Production Locations
NFPA 150 Standard on Fire and Life Safety in Animal Housing Facilities
NFPA 160 Standard for the Use of Flame Effects Before an Audience
NFPA 170 Standard for Fire Safety and Emergency Symbols
NFPA 204 Standard for Smoke and Heat Venting
NFPA 211 Standard for Chimneys, Fireplaces, Vents, and Solid Fuel-Burning Appliances
NFPA 214 Standard on Water-Cooling Towers
NFPA 220 Standard on Types of Building Construction
NFPA 221 Standard for High Challenge Fire Walls, Fire Walls, and Fire Barrier Walls
NFPA 225 Model Manufactured Home Installation Standard
NFPA 232 Standard for the Protection of Records
NFPA 241 Standard for Safeguarding Construction, Alteration, and Demolition Operations
NFPA 251 Standard Methods of Tests of Fire Resistance of Building Construction and Materials
NFPA 252 Standard Methods of Fire Tests of Door Assemblies
NFPA 253 Standard Method of Test for Critical Radiant Flux of Floor Covering Systems Using a Radiant Heat Energy Source
NFPA 255 Standard Method of Test of Surface Burning Characteristics of Building Materials
NFPA 257 Standard on Fire Test for Window and Glass Block Assemblies
NFPA 259 Standard Test Method for Potential Heat of Building Materials
NFPA 260 Standard Methods of Tests and Classification System for Cigarette Ignition Resistance of Components of Upholstered Furniture
NFPA 261 Standard Method of Test for Determining Resistance of Mock-Up Upholstered Furniture Material Assemblies to Ignition by Smoldering Cigarettes
NFPA 262 Standard Method of Test for Flame Travel and Smoke of Wires and Cables for Use in Air-Handling Spaces
NFPA 265 Standard Methods of Fire Tests for Evaluating Room Fire Growth Contribution of Textile Coverings on Full Height Panels and Walls
NFPA 268 Standard Test Method for Determining Ignitibility of Exterior Wall Assemblies Using a Radiant Heat Energy Source
NFPA 269 Standard Test Method for Developing Toxic Potency Data for Use in Fire Hazard Modeling
NFPA 270 Standard Test Method for Measurement of Smoke Obscuration Using a Conical Radiant Source in a Single Closed Chamber
NFPA 271 Standard Method of Test for Heat and Visible Smoke Release Rates for Materials and Products Using an Oxygen Consumption Calorimeter
NFPA 274 Standard Test Method to Evaluate Fire Performance Characteristics of Pipe Insulation
NFPA 275 Standard Method of Fire Tests for the Evaluation of Thermal Barriers Used Over Foam Plastic Insulation
NFPA 276 Standard Method of Fire Tests for Determining the Heat Release Rate of Roofing Assemblies with Combustible Above-Deck Roofing Components
NFPA 285 Standard Fire Test Method for Evaluation of Fire Propagation Characteristics of Exterior Non-Load-Bearing Wall Assemblies Containing Combustible Components
NFPA 286 Standard Methods of Fire Tests for Evaluating Contribution of Wall and Ceiling Interior Finish to Room Fire Growth
NFPA 287 Standard Test Methods for Measurement of Flammability of Materials in Cleanrooms Using a Fire Propagation Apparatus (FPA)
NFPA 288 Standard Methods of Fire Tests of Floor Fire Door Assemblies Installed Horizontally in Fire Resistance-Rated Floor Systems
NFPA 289 Standard Method of Fire Test for Individual Fuel Packages
NFPA 290 Standard for Fire Testing of Passive Protection Materials for Use on LP-Gas Containers
NFPA 291 Recommended Practice for Fire Flow Testing and Marking of Hydrants
全部回复(15 )
  • zrq778
    zrq778 沙发
    谢谢楼主的无私分享!
    2017-05-09 22:40:09
  • guan-xiang.liu
    高,实在是高!
    2013-11-01 15:36:01
建筑消防给水
28.41 万条内容 · 745 人订阅
灭火器充装
ABC干粉灭火器的到了多久必须重新充装?而不管其压力是否正常。这是在哪个法规或规范中规定的?我只查到灭火器的报废年限,而找不到充装年限。哪位大哥大姐知道的麻烦指点下,小弟不胜感激
