返回版块97.93 万条内容 · 2230 人订阅
MKP电容器(圆柱形)越华电容器,领先国内,同步世界!1.损耗低,介质采用了聚丙烯金属化薄膜,使耗损率降至0.12%以下,发热小,温升低,自愈能力强,使运行寿命更长;1. Low loss, dieletric properties /medium adopt the Metallized Polypropylene film. Because the actual loss is less then 0. 12%, the raised temperature is low, operation life is long and it has outstanding saving energy result., good self-healing performance, make the life longer.
只看楼主 我来说两句 抢板凳
