土木在线论坛 \ 电气工程 \ 供配电技术 \ MKP电容器(圆柱形)
MKP电容器(圆柱形)
发布于:2008-08-27 15:48:27 来自:电气工程/供配电技术 [复制转发]
越华电容器,领先国内,同步世界!
1.损耗低,介质采用了聚丙烯金属化薄膜,使耗损率降至0.12%以下,发热小,温升低,自愈能力强,使运行寿命更长;
1. Low loss, dieletric properties /medium adopt the Metallized Polypropylene film. Because the actual loss is less then 0. 12%, the raised temperature is low, operation life is long and it has outstanding saving energy result., good self-healing performance, make the life longer.
2.电气性能优良,采用最先进的制造工艺,使绝缘电阻提高,电容量损失降至最低,长期运行也能保持优良稳定的电气性能。
2. Electrical capability fine, adopt the most advanced manufacture craft, makes the dielectric resistance to enhance, the capacity loss falls to the lowest, can maintain the fine and stable electric capability in long-term movement.
3.选用铝材作为电容器的外壳,坚固不生锈,散热性能优越于其它材料;
3. The crust of capacitor made of aluminum, strong and rustless, the capability of heat dissipation is superior to other materials.
4.铜材螺栓接线端子设计合理,避免短路,使端子导线连接良好;
4. Brass pole terminal design in reason, avoid short-circuit, terminal lead connection well.
5.产品整体密封,内装安全保护装置,采用超压自动拉断内部安全装置,双重电气保护;
5. Products are airproof, build-in the security protector. A unique Sequential Protection System ensures safety of using
6.内装放电电阻,电源断电后,3分钟内电压降至50V以下;
6.Permanently connected built-in discharge resistors are sized to ensure safe discharge of the capacitor to less than 50V in 3min after power broke down
7. 产品安装方便、简洁;(椭圆形有配安装脚,圆柱形底部的接地螺栓为安装脚)
7. Capacitor is very lightweight and therefore presents no handling difficulting during installation. (the ellipse series fitted with a mounting stud, the bolt of cylindrical series is the mounting stud.)
*多级安全保护系统
1.真空灌封技术:电容器内充特殊的保护介质,不泄漏、安全环保;避免环境污染、火灾等风险。
Vacuum casting technology: special protective medium filled in capacitor, not leak, security and environmental; to avoid environmental pollution, fire and other risks
2.自愈性:优良的自愈性能,当过电压所造成的介质局部击穿能迅速自我修复,恢复正常工作。
Self-healing: excellent self-healing capability can self-repair quickly and renew to working when over pressure destroy the part of medium.
3.安全保护装置:(获得专利)过压拉断可防止电容器在邻近寿命服务期限或由于电器过载及过热而引发事故。
Security installation :( Patented)over pressure snap can prevent capacitor to bring accident when close to use life or capacitor’s over heat. 4.新型、安全、可靠的接线端子可以更方便地连接,隐藏式设计,防止意外触摸,结构独特:
new type, security and dependable terminal lead connect more convenience, Perdue design prevent accidental touch, unique structure
.电容器的输入端简化了并联应用方式。
Capacitor’s terminal predigest the Parallel application form
.防电击危险保护
Prevent tip-and-run protection
.内置放电电阻和保险装置,使用安全可靠
Building-in discharge resistance and safety installation, the use of safe and reliable
.电缆横截面可高达16mm2
cable’s cross section can up to 16mm2
*优越电性能
对于无功功率,MKP、CLMD系列低压电容器可极大地改进功率质量和降低能量损失:
Reactive power, CLMD low-voltage capacitor can improve power quality and reduce loss of energy
★降低或消除因低功率因数而带来的昂贵代价
Reduce or eliminate the high cost
★降低电缆和变压器中的功率损失,增加电缆电力传输能力
Reduce the power loss of cable and transformer
★增加变压器容量
Increase transformer capacity
★改善长电缆中的电压稳定性
Improve long cable’s voltage stability
★节能、环保、安全、可靠
Economize, environmental, security and reliable
97.93 万条内容 · 2230 人订阅
越华电容器,领先国内,同步世界! 帮助有需要的朋友,认识国产电容器.
帮助有需要的朋友!认识国产电容器.越华电容器同步世界,领先国内!广东巨华电力电容器制造公司,10多年产销自愈式低压并联电力电容器的经验,目前已是国内技术最先进,生产最具专业化的电力电容器制造商.产品出口到欧洲与东南亚多个国家.用于低压设备的功率因数校正和电压波形的改善! 佛山市顺德区巨华电力电容器制造有限公司是一家专业生产与销售自愈式低压并联电力电容器的企业,原企业名称为顺德市容桂越华电容器厂,于1998年建厂,通过多年的发展,公司的规模逐渐扩大,目前已成为国内技术最先进、生产最具专业化的制造商之一,同时产品出口到欧美与东南亚等多个国家,2005年企业名称更名为佛山市顺德区巨华电力电容器制造有限公司,产品商标与品牌不变,还是“越华”牌电力电容器。
