土木在线论坛 \ 暖通空调 \ 制冷技术 \ 老外 diy 的 深冷复叠
老外 diy 的 深冷复叠
发布于:2008-08-20 12:15:20 来自:暖通空调/制冷技术 [复制转发]
记得有人做过-150,但不是这个
compressors: Toshiba PG180-X1C on 1st stage (11000 BTU) and TECO KETC176ELBC-A on 2nd stage (10755 BTU)
evap: steeper, 40 mm tall
XV: Danfoss TES2 / captube 0.9 mm
HX: Plate HX, 12 plates
condenser: double condensor, 2 x 2 rows condensors, cooled by 4 x 120/38mm mm high flow fans (NBM and Sunon)
refrigerants : R507/R1150
oilseparator : ESK Schultze with automatic oil back
safety : RANCO cut-off
case : Steel zincked baseplate - 50 x 35 cm
others: LCD HX out temperature display, 2 gagues - on both stages' discharge, wheels for baseplate, 28 mm thick insulation on suction line
全部回复(27 )
  • cnnx1
    cnnx1 沙发
    图片都删了,还留这个话题做什么,还不如都删了!!
    2011-01-27 21:13:27
  • 火火兔
    火火兔 板凳
    好玩!好玩!这老外是个制冷发烧友!!!
    2011-01-26 12:40:26
制冷技术
14.68 万条内容 · 886 人订阅
紧急求助:冰轮氟螺杆制冷机吸气压力非常低
我单位新安装几台带经济器的氟螺杆制冷机,其中几台吸气压力一直非常低,今天采集了一台-35度机组的几组数据,请各位大侠帮我分析下:盐水出口温度(摄氏度): -12.2 -13.1 -19.1 -21.0 -23.6 吸气压力(bar) : -0.25 -0.24 -0.29 -0.3 -0.32排气压力(bar) : 12.64 13.09 13.11 13.08 油压(bar) : 14.24 14.54 14.46 14.44
