土木在线论坛 \ 电气工程 \ 输变电工程 \ 关于HVAC的相关问题
关于HVAC的相关问题
发布于:2008-07-20 16:55:20 来自:电气工程/输变电工程 [复制转发]
Principal/Assoc Principal/Senior/R&D Engineer, HVAC
我们的客户是世界上最大的欧洲风力发电公司,在丹麦,新加坡,北京建立了研发中心,现委托我们诚聘研发中心的职位:
Our client is a world leading Energy company with Asia R&D HQ in Singapore. We are looking fro strong R&D candidates in many different areas, including this HVAC.
The Job:
• You will be responsible for coordinating and liaising with conditioning team, supplier and local authorities as required to carry out projects.
• You will design, develop technical specification for HVAC and evaluate HVAC for its technical requirements.
• You will also prototype development and validate with supplier, prepare global specification and data sheet for HVAC and prepare technical bid evaluation/selection for supplier’s capability.
• You will review and check HVAC specifications and drawings.
The person:
Proficiency in the broad technical expertise in all the following:
• Broad background in HVAC which includes specification, product validation and supplier selection, implementation within energy technologies
• Knowledge of heat exchanger design, analysis and selection
• Good knowledge of heat transfer and fluid flow analysis
If you are interested in our clients and this position, PLS send your CV to
kally.chen@access-people.com or kallychen2006@gmail.com
Phone:021-62182121-803 (Kally Chen)
输变电工程
11.1 万条内容 · 662 人订阅
电能计量
我部有一块三相电度表(数显三段表)用于变压器一次侧的计量,电压互感器为100倍(高压),电流互感器为20倍(高压两块),经鉴定均为合格在允差范围内,接线正确,但是计量出来的电量与实际用量不符,高出3倍左右,怎么回事啊
