土木在线论坛 \ 人才招聘 \ 学生专栏 \ 建筑行业分类英语13(设计常用词汇3)
建筑行业分类英语13(设计常用词汇3)
发布于:2008-06-19 13:05:19 来自:人才招聘/学生专栏 [复制转发]
 耐久性 durability, endurance
  爬梯 cat ladder
  疲劳破坏 fatigue failure
  频率 frequency
  平面布置 plan layout
  平台 terrace, platform, deck
  平台栏杆 platform railing
  剖面 section
  剖面图 sectional drawing
  侵蚀 corrosion, erosion
  倾覆 overturning, toppling
  人孔 manhole
  容许误差 allowable error, permissible error
  容许值 permissible value, allowable value
  晒图 blueprinting
  上部结构 superstructure
  设计要求 design requirements
  设计资料 design data
  伸缩缝 expansion joint
  室外楼梯 exterior stair, outside stairway
  双向板 two-way slab
  水平撑 horizontal brace
  踏步 step
  踏步板 tread
  弹簧 spring
  填充材料 filling material
  填充墙 filler wall
  挑板 cantilever slab
  挑檐 projecting eaves, overhang eaves
  停车场 car park, parking lot
  通用构件 standard member
  通用图 standard drawing
  通用详图 standard detail
  统一标准 unified standards
  统一构件 unified structure element
  投标 bid, tender
  招标 bidding
  图集 collective drawings, collection of drawings
  图签 title block
  温差 temperature difference
  稳定性 stability, steadiness
  污水处理 sewage disposal, sewage treatment
  先张法预应力 pretensioned prestressing
  现行标准 currently effective standards
  详图, 大样 detail drawing, detail
  橡胶止水带 rubber waterstop
  消防 firefighting, fire protection
  斜率 slope
  卸荷 unloading
  卸货平台 discharging platform, unloading platform
  悬臂 cantilever
  悬臂板 cantilever slab
  悬臂梁 cantilever beam, overhanging beam
  悬挂 hanging suspension
  压缩机 compressor
  压缩模量 modulus of compression
  延性 ductility, ductileness
  业主 client, owner
  一览表 table, schedule, list
  有效截面 effective section
  预应力损失 loss of prestress, prestressing loss
  圆形 circular shape, round
  圆柱 circular column, round column
  约束 confinement, restraint, constraint
  约束条件 constrain condition
  展开图 developed drawing
  栈桥 landing stage, loading bridge
  罩棚 awning
  折减系数 reduction factor
  折算高度 reduced height
  支座 support, pedestal
  直爬梯 vertical ladder
  止水带 water stop
  中和轴 neutral axis
  重心 center of gravity
  周期 period, cycle
  转弯半径 turning radius
  转动惯量 rotational inertia
  装卸平台 loading and unloading platform
  • 任昱丞
    任昱丞 沙发
    呵呵 学 习 了!
    2009-09-22 20:02:22
学生专栏
23.9 万条内容 · 138 人订阅
建筑行业分类英语13(设计常用词汇2)
  防滑条 non-slip insert  防火 fire prevention, fire proofing  防火材料 fireproof material  防火分区 fire compartment  防水 waterproofing  防水材料 waterproof material  防水砂浆 waterproof mortar  防酸 acid proofing  方形 square
