土木在线论坛 \ 人才招聘 \ 学生专栏 \ 建筑行业分类英语10(钢结构)
建筑行业分类英语10(钢结构)
发布于:2008-06-19 13:02:19 来自:人才招聘/学生专栏 [复制转发]
 d. Steel Structure 钢结构
  薄壁型钢 light-gauge steel section,
   hollow steel section
  不等肢角钢 unequal angle steel
  槽钢 channel, channel steel
  背对背角钢组合 angles back to back
  不锈钢 stainless steel
  除锈 rust-removal
  粗制螺栓 rough bolt, black bolt
  带钢 strip steel, band iron
  单面焊 single weld, one-side welding
  地脚螺栓 foundation bolt, anchor bolt,
   holding down bolt
  点焊 spot welding, point welding
  电动葫芦 electric hoist
  等边角钢 equal angle, equal leg angle
  对接焊, 对焊 butt welding
  腹板 web plate, web
  腹杆 web member
  腹板加劲件 web stiffener
  杆 rod, bar
  钢板 steel plate
  钢管 steel tube, steel pipe
  钢桁架 steel truss
  钢框架 steel frame
  钢梯, 爬梯 steel ladder
  高强度螺栓 high strength bolt
  格构柱 lattice column
  工字梁 I-girder, I-beam
  工字钢 I-steel
  工字形截面 I-shaped cross-section
  焊缝 welding seam
  焊接 welding
  焊接长度 weld length
  焊条 welding rod
  桁架 truss
  红丹底漆 red lead primer
  红丹漆 red lead paint
  加劲肋 stiffening rib, rib stiffener
  加劲板 stiffening plate
  角钢 angle steel
  节点 joint, node
  节点板 gusset plate, gusset
  节点位移 joint displacement
  节间长度 panel length
  紧固螺栓 clamp bolt, fastening bolt
  精制螺栓 turned bolt
  可焊性 weldability
  空腹桁架 open-web truss
  空间桁架 space truss
  肋板 ribbed panel, ribbed slab
  连接板 connecting plate, joint plate
  檩条 purline
  螺母 screw nut, nut
  螺栓 bolt
  螺栓孔 bolt hole
  螺纹 screw thread, thread
  螺纹长度 length of thread
  螺纹钢 screw-threaded steel, twisted steel
  拉杆 tie rod, tension rod
  满焊 full weld
  铆钉 rivet
  锰钢 manganese steel
  喷砂 sand blasting
  轻钢结构 lightweight steel construction
  三角架 tripod
  上弦 top chord, upper chord
  上弦横向水平支撑 upper lateral bracing
  上弦纵向水平支撑upper longitudinal bracing
  平面桁架 plane truss
  实腹刚架 solid web rigid frame
  塔架 pylon bent
  特种钢 special steel
  调和漆 mixed paint
  贴角焊 fillet weld, fillet welding
  托架 bracket
  网架结构 grid structure
  屋架 roof truss, principal
  无缝钢管 seamless steel pipe
  系杆 tie rod, tie bar, tie
  下弦 bottom chord, lower chord
  下弦横向水平支撑 bottom lateral bracing
  斜撑 diagonal brace, diagonal bracing
  型钢 section steel, shaped steel
  悬索 suspended cable, suspension cable
  压力焊 pressure welding
  仰焊 overhead welding, inverted welding
  翼缘 flange
  翼缘板 flange plate, cover plate
  轧制型钢 rolled steel section
  支撑 bracing, strutting
  铸铁管 cast iron pipe
  组合槽钢 built-up channel
  组合截面built-up section,compound section
  自动焊接 automatic welding
  • 量子
    量子 沙发
    不错,正在愁这方面的资料呢,正好学习学习一下,谢谢楼主上传.继续努力!
    2009-05-18 19:43:18
学生专栏
23.9 万条内容 · 138 人订阅
建筑行业分类英语5(金属材料)
Metallic Materials 金属材料     黑色金属 ferrous metal  圆钢 steelbBar  方钢 square steel  扁钢 steel atrap  型钢 steel section (shape)  槽钢 channel  角钢 angle steel  等边角钢 equal-leg angle  不等边角钢 unequal-leg angle
