土木在线论坛 \ 人才招聘 \ 学生专栏 \ 建筑行业分类英语5(金属材料)
建筑行业分类英语5(金属材料)
发布于:2008-06-19 12:57:19 来自:人才招聘/学生专栏 [复制转发]
Metallic Materials 金属材料
  黑色金属 ferrous metal
  圆钢 steelbBar
  方钢 square steel
  扁钢 steel atrap
  型钢 steel section (shape)
  槽钢 channel
  角钢 angle steel
  等边角钢 equal-leg angle
  不等边角钢 unequal-leg angle
  工字钢 I-beam
  宽翼缘工字钢 wide flange I-beam
  丁( 之)字钢 T-bar (Z-bar)
  冷弯薄壁型钢light gauge cold-formed steel shape
  热轧 hot-rolled
  冷轧 cold-rolled
  冷拉 cold-drawn
  冷压 cold-pressed
  合金钢 alloy steel
  钛合金 titanium alloy
  不锈钢 stainless steel
  竹节钢筋 corrugated steel bar
  变形钢筋 deformed bar
  光圆钢筋 plain round bar
  钢板 steel plate
  薄钢板 thin steel plate
  低碳钢 low carbon steel
  冷弯 cold bending
  钢管 steel pipe (tube)
  无缝钢管 seamless steel pipe
  焊接钢管 welded steel pipe
  黑铁管 iron pipe
  镀锌钢管 galvanized steel pipe
  铸铁 cast iron
  生铁 pig iron
  熟铁 wrought iron
  镀锌铁皮 galvanized steel sheet
  镀锌铁丝 galvanized steel wire
  钢丝网 steel wire mesh
  多孔金属网 expanded metal
  锰钢 managanese steel
  高强度合金钢 high strength alloy steel
  • Non-Ferrous Metal 有色金属
  金 gold
  白金 platinum
  铜 copper
  黄铜 brass
  青铜 bronze
  银 silver
  铝 aluminum
  铅 lead
  • Anti-Corrosion Materials 防腐蚀材料
  聚乙烯 polythene, polyethylene
  尼龙 nylon
  聚氯乙烯 PVC (polyvinyl chloride)
  聚碳酸酯 polycarbonate
  聚苯乙烯 polystyrene
  丙烯酸树酯 acrylic resin
  乙烯基酯 vinyl ester
  橡胶内衬 rubber lining
  氯丁橡胶 neoprene
  沥青漆 bitumen paint
  环氧树脂漆 epoxy resin paint
  氧化锌底漆 zinc oxide primer
  防锈漆 anti-rust paint
  耐酸漆 acid-resistant paint
  耐碱漆 alkali-resistant paint
  水玻璃 sodium silicate
  树脂砂浆 resin-bonded mortar
  环氧树脂 epoxy resin
  • Building Hardware 建筑五金
  钉子 nails
  螺纹屋面钉spiral-threaded roofing nail
  环纹石膏板钉annular-ring gypsum board nail
  螺丝 screws
  平头螺丝 flat-head screw
  螺栓 bolt
  普通螺栓 commercial bolt
  高强螺栓 high strength bolt
  预埋螺栓 insert bolt
  胀锚螺栓 cinch bolt
  垫片 washer
  • jingaocheng
    jingaocheng 沙发
    不错,很有帮助,谢谢分享,顶一下
    2008-06-28 23:47:28
学生专栏
23.9 万条内容 · 138 人订阅
建筑行业分类英语3
g. FLOOR AND TRENCH   地面及地沟        地坪 grade  地面和楼面 ground and floor  素土夯实 rammed earth  炉渣夯实 tamped cinder  填土 filled earth  回填土夯实 tamped backfill  垫层 bedding course, blinding  面层 covering, finish
