土木在线论坛 \ 人才招聘 \ 学生专栏 \ 建筑行业分类英语3
建筑行业分类英语3
发布于:2008-06-19 12:56:19 来自:人才招聘/学生专栏 [复制转发]
g. FLOOR AND TRENCH
  地面及地沟
  地坪 grade
  地面和楼面 ground and floor
  素土夯实 rammed earth
  炉渣夯实 tamped cinder
  填土 filled earth
  回填土夯实 tamped backfill
  垫层 bedding course, blinding
  面层 covering, finish
  结合层 bonding (binding) course
  找平层 leveling course
  素水泥浆结合层
   neat cement binding course
  混凝土地面 concrete floor
  水泥地面 cement floor
  机器磨平混凝土地面
   machine trowelled concrete floor
  水磨石地面 terrazzo flooring
  马赛克地面 mosaic flooring
  瓷砖地面 ceramic tile flooring
  油地毡地面 linoleum flooring
  预制水磨 石地面 precast terrazzo flooring
  硬木花地面 hard-wood parquet flooring
  搁栅 joist
  硬木毛地面 hard-wood rough flooring
  企口板地面tongued and grooved flooring
  防酸地面 acid-resistant floor
  钢筋混凝土楼板
   reinforced concrete slab (R.C Slab)
  乙烯基地面 vinyl flooring
  水磨石嵌条 divider strip for terrazzo
  地面做2%坡 floor with 2% slope
  集水沟 gully
  集水口 gulley
  排水沟 drainage trench
  沟盖板 trench cover
  活动盖板 removable cover plate
  集水坑 sump pit
  孔翻边 hole up stand
  电缆沟 cable trench
  h. DOORS,GLASS,WINDOWS & IRONMONGERY(HARDWARE)
   门、玻璃、窗及五金件
  木 (钢)门 wooden (steel) door
  镶板门 panelled door
  夹板门 plywood door
  铝合金门 aluminum alloy door
  卷帘门 roller shutter door
  弹簧门 swing door
  推拉门 sliding door
  平开门 side-hung door
  折叠门 folding door
  旋转门 revolving door
  玻璃门 glazed door
  密闭门 air-Tight door
  保温门 thermal insulating door
  镀锌铁丝网门galvanized steel wire mesh door
  防火门 fire door
  (大门上的)小门 wicket
  门框 door frame
  门扇 door leaf
  门洞 door opening
  结构开洞 structural opening
  单扇门 single door
  双扇门 double door
  疏散门 emergency door
  纱门 screen door
  门槛 door sill
  门过梁 door lintel
  上冒头 top rail
  下冒头 bottom rail
  门边木 stile
  门樘侧料 side jumb
  槽口 notch
  木窗 wooden window
  钢窗 steel window
  铝合金窗 aluminum alloy window
  百叶窗 (通风为主) sun-bind, louver (louver, shutter, blind)
  塑钢窗 plastic steel window
  空腹钢窗 hollow steel window
  固定窗 fixed window
  平开窗 side-hung window
  推拉窗 sliding window
  气窗 transom
  上悬窗 top-hung window
  中悬窗 center-pivoted window
  下悬窗 hopper window
  活动百叶窗 adjustable louver
  天窗 skylight
  老虎窗 dormer window
  密封双层玻璃 sealed double glazing
  钢筋混凝土过梁reinforced concrete lintel
  钢筋砖过梁 reinforced brick lintel
  窗扇 casement sash
  窗台 window sill
  窗台板 window board
  窗中梃 mullion
  窗横木 mutin
  窗边木 stile
  压缝条 cover mould
  窗帘盒 curtain box
  合页(铰链) hinge (butts)
  转轴 pivot
  长脚铰链 parliament hinge
  闭门器 door closer
  地弹簧 floor closer
  插销 bolt
  门锁 door lock
  拉手 pull
  链条 chain
  门钩 door hanger
  碰球 ball latch
  窗钩 window catch
  暗插销 insert bolt
  电动开关器 electric opener
  平板玻璃 plate glass
  夹丝玻璃 wire glass
  透明玻璃 clear glass
  毛玻璃(磨砂玻璃) ground glass (frosted glass)
  防弹玻璃 bullet-proof glass
  石英玻璃 quartz glass
  吸热玻璃 heat absorbing glass
  磨光玻璃 polished glass
  着色玻璃 pigmented glass
  玻璃瓦 glass tile
  玻璃砖 glass block
  有机玻璃 organic glass
全部回复(5 )
  • 丨灬郭
    丨灬郭 沙发
    这个有什么用呢。。。没搞懂???图纸不都是中文的简写么
    2014-07-21 18:15:21
  • qq_1401203947836
    不错。。。
    2014-07-20 00:06:20
学生专栏
23.9 万条内容 · 138 人订阅
建筑行业分类英语
 d. GENERAL ROOM NAME    常用房间名称     办公室 office  服务用房 service room  换班室 shift room  休息室 rest room (break room)  起居室 living room  浴室 bathroom  淋浴间 shower  更衣室 locker room  厕所 lavatory   门厅 lobby
