土木在线论坛 \ 园林景观 \ 景观规划设计 \ 伴水而居、自然融入,常州万科潮起东方
伴水而居、自然融入,常州万科潮起东方
发布于:2023-09-15 11:16:15 来自:园林景观/景观规划设计 [复制转发]
常州万科潮起东方项目位于东方新城核心居住区及商业级旅游重点打造区域,毗邻城市主干道及城市滨河绿带,居住氛围浓厚,有着得天独厚的区位优势。在现今这个现代化大都市中,如何在都市与自然、工作与生活中寻求平衡,打造一个都市生态社区,满足新一代品质住宅业主对居住环境的需求,成为了项目设计与营造的出发点。
The Changzhou Vanke Chaoqi East Project, is located in the core residential area of Dongfang New City and a key commercial tourism development area,is adjacent to the city's main roads and riverside green belts, with a strong residential atmosphere and unique geographical advantages. In this modern metropolis, how to find a balance between the city and nature, work and life, and create an urban ecological community to meet the needs of the new generation of high-quality residential owners for the living environment has become the starting point of project design and construction.
△项目区位图
项目以多维的空间设计为中心,将自然元素带入整体主调性,以现代简约的设计手法与匠心精致的营造细节相融合,以“贪玩的角落”亲子互动区,“青年秀场”运动活力空间,“漫生活剧场”长辈活动区,“岛屿会客厅”友邻聚场为节点,打造尊贵的都市品质感以及生态绿化氛围,让闲适重回生活,创造理想的滨水人居环境。
The project revolves around a multi-dimensional spatial design, incorporating natural elements into the overall theme, combining modern and minimalist design techniques with exquisite details to create a noble sense of urban quality and ecological greening atmosphere,the nodes include the "Playful corner" parent-child interaction area, the "Youth show" sports vitality space, the "Man Life Theater" senior activity area, and the "Island Reception Hall" neighborhood gathering area, allowing leisure to return to life and create an ideal waterfront living environment.
家园是每一个人身心放松的港湾,常州万科潮起东方以现代主义风格为基调,入口利用简约而充满体块感的形态,搭配金属线条及定制灯带,以精品工艺呈现酒店式轻奢质感。大门整体钢结构紧密,以较轻的自重稳定的结构,搭配冷色材质,营造出高级、大气的空间气场。
Home is a harbor for everyone's physical and mental relaxation. Changzhou Vanke Chaoqi East adopts a modernist style as the keynote, and the entrance uses a simple and block like form, paired with metal lines and customized light strips, to present a hotel style luxurious texture with exquisite craftsmanship. The overall steel structure of the gate is tight, with a relatively light and stable self weight structure, paired with cold colored materials, creating a high-end and atmospheric spatial atmosphere.
入口小广场铺装设计使用简洁舒展的几何线条,延伸至对景式logo景墙花园,由几何式的浅色景墙搭配高大的观赏乔木及组团植物,增强区域空间感。同时通行处阵列式种植对称的落叶乔木,营造仪式感。
The paving design of the entrance square uses simple and stretchy geometric lines, extending to the landscape style logo wall garden. The geometric light colored wall is paired with tall ornamental trees and group plants to enhance the sense of regional space. Simultaneously planting symmetrical deciduous trees in an array pattern creates a sense of ceremony.
不同色彩的铺装,精密的石材对缝效果,无明显色差,不同的铺装交界处对缝,同时拼缝宽窄一致、顺直,在弧形铺装处采用水刀切割弧形板,弧线流畅。加上圆滑自然的转角收边处理,无处不展现施工团队超强的工艺水平。
The paving with different colors, precise stone seam matching effect, There is no obvious color difference, and the joints between different paving surfaces are aligned. At the same time, the width of the joints is consistent and straight. At the curved paving area, a water knife is used to cut the curved plate, with a smooth arc and smooth and natural corner trimming treatment demonstrate the strong craftsmanship of the construction team .
进入中心大草坪区,“多维度”氧气森林剧场为人们带来了多样的生活休闲空间。精致的钢结构金属廊架,细节处理彰显轻盈。现代简约式的几何空间设计,每一处金属线条及收边都展现出了工艺的用心与匠心。同时也为业主开辟出一处,可以与家人邻里相伴的休闲区域,感受这平凡中的幸福生活。
Entering the central lawn area, the "multi-dimensional" oxygen forest theater provides people with diverse living and leisure spaces. Exquisite steel structure metal frame with lightweight details. The modern minimalist geometric space design showcases craftsmanship and craftsmanship in every metal line and edge. At the same time, it also creates a leisure area for homeowners to accompany their homes and neighbors, and experience the happiness of this ordinary life.
木平台与草坪空间巧妙融合,整个场地平整度很好,基层采用沟槽导水,不起鼓不积污,为业主休憩、邻里交谈、接待访友打造一方自然天地。草坪下排布盲管,雨水可以有效排放,满足露天影院、露营、亲子等多重功能。
The wooden platform cleverly integrates with the lawn space, The overall ground level is very good, and the base layer adopts grooves for water diversion, which does not bulge or accumulate dirt creating a natural world for homeowners to rest, chat with neighbors, and receive visitors. Lay blind pipes under the lawn, which can effectively discharge rainwater and meet multiple functions such as outdoor cinema, camping, parent-child.
以点阵树列、整形灌木以及点景大乔,丰富了中心草坪场景,同时对外界视线形成遮挡,赋予场域一定的半私密性和更多可使用性。
The use of dot matrix tree columns, shaping shrubs, and point view trees enriches the central lawn scene, while also obstructing the external view, giving the field a certain degree of semi privacy and more usability.
美好的亲子时光已经成为人们生活中的重要部分,EDTM树胶活动场地不仅色彩明艳,同时也为儿童游乐过程中增添了安全性。而精心打造的儿童游玩空间,设施精良充满童趣,为孩子们带来了不一样的童趣体验。
The beautiful parent-child time has become an important part of people's lives, and the EDTM gum activity venue not only has bright colors, but also adds safety to children's play. The meticulously crafted children's play space, with sophisticated facilities and a childlike atmosphere, brings children a unique gaming experience.
△儿童游乐区效果图
由彩色透水混凝土组成的环绕社区的健康慢跑道,运用特殊工艺达到防泛碱、防开裂的效果,为业主提供了尽情唤醒身体,享受运动乐趣的场所。在慢跑的过程中,穿越社区花园、林中夹道,绿植环绕之中迎接清新的气息。
The healthy slow track surrounding the community, composed of colored permeable concrete, uses special techniques to achieve anti alkali and anti cracking effects, providing owners with a place to fully awaken their bodies and enjoy sports fun. During the process of jogging, cross the community gardens and forest alleys, surrounded by green plants to welcome the fresh atmosphere.
起伏的微地形搭配植物组团,在每一处空间的处理上,将收放、开合的植物种植方式发挥到极致,乔木下的灌木丛及地被,层次丰富,边线收口顺畅,整体饱满圆润,后期维护精修剪,营造宜人的自然生活场景。
The undulating micro terrain is combined with plant clusters, and in each spatial processing, the plant planting methods of folding and opening are maximized. The shrubs and ground cover under the trees are rich in layers,Smooth closing of the edge line, overall plump and round, with later maintenance and fine trimming,creating a pleasant natural living scene.
流畅的人行道路,在多个缓坡及植物的掩映之间宛然延伸,引导业主走向归家之旅。入户景墙上金属线条细节精巧,植被空间形成港湾式尺度,营造归家仪式感。
The smooth pedestrian road extends between multiple gentle slopes and the interplay of plants, guiding homeowners towards their homecoming journey. The metal lines on the entrance wall are exquisitely detailed, and the vegetation space forms a harbor like scale, creating a sense of returning home ceremony.
人们漫步至林下空间,简洁的铺装与可以移动的设施相结合,降低成本及落地周期的同时,也有效软化了大面积的消防登高面带来的硬质感,将度假休闲感传递进社区,让慢生活体验融入社区。
People stroll into the understory space, combining simple paving with movable facilities to reduce costs and landing cycles. At the same time, it effectively softens the hard feeling brought by the large area of fire climbing surfaces, transmitting the sense of vacation and leisure into the community, and integrating the slow life experience into the community.
我们知道每一个项目落地的背后,都是包含设计、施工、管理等全体工作人员的辛勤的付出与努力。
We know that behind the implementation of each project, there is the hard work and effort of all staff including design, construction, and management.
常州万科潮起东方项目的优越品质源于精益求精的态度,从每一根线条的产生,到每一处细节的落地,团队以匠心精研每一处细节,同时以高标准,严要求,保证项目落地品质。
The superior quality of Changzhou Vanke Chaoqi East (Bincui Yayuan) project stems from an attitude of striving for excellence. From the generation of every line to the implementation of every detail, the team meticulously studies every detail with craftsmanship, while ensuring the quality of project implementation with high standards and strict requirements.
每一个项目,每一种工艺的完美呈现,都是多方通力合作的结果,合理配置各种项目资源,将品质落实细节之上,让方案步步落地。最后感谢所有参与者对于项目的付出,以匠心,筑造美好生活的更多可能。
The perfect presentation of each project and process is the result of joint efforts from multiple parties, rational allocation of various project resources, implementation of quality details, and gradual implementation of the plan. Finally, I would like to express my gratitude to all participants for their dedication to the project and for their ingenuity in creating more possibilities for a better life.
项目信息
项目名称:常州万科潮起东方项目景观工程
项目地址:华丰路西侧 东方三路北侧
项目面积:22385m2
甲方团队:陈正广、吴志国、鲍晓铭、姚瑞
景观设计:南京中山园林设计有限公司
景观施工:陕西碧景荟生态绿化工程有限公司
施工周期:2023年2月5日-2023年9月30日
项目摄影:园景人摄影
文章撰写:园景人
景观规划设计
25.18 万条内容 · 282 人订阅
超实用!小庭院景观设计——让小庭院更具质感和个性
在庭院的设计过程中,地面铺装是必不可少的环节,也是庭院硬质景观中不可或缺的组成部分。地面铺装除了美观外,还有一定的功能性,例如,划分不同的功能区,可作为过人的通道以及防草,防止杂草滋生。此外,铺装材料的材质、色彩也能丰富庭院的景观效果。 在选择小庭院地面铺装材料时,首先考虑材料表面的平整度、防滑性、耐久性和透水性等关键要素,以保证后期园主使用的安全问题,其次考虑色彩、机理等美学层面的问题。例如,为顺应小庭院的面积,使用一些兼备功能性的镶边材料,一定会使小院子更加多变。
