很久以前我常常使用CAD中的vlisp语言连接Access数据库,进行画纵断面图。现在发现用以前的程序出现“错误: Automation 错误。 未找到提供程序。该程序可能未正确安装。”的提示。原数据库的连接函数为:
(defun tls-ado-opencon(filename / con connectionstring)
(setq con (vlax-create-object "ADODB.Connection"))
(setq
connectionstring
(strcat
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source="
filename
";Persist Security Info=False"
(vla-open con connectionstring "" "" -1)
con
在网上查找,也找不到解决的办法。后来,我把要用的数据库导入MSSQL,我用的是SQL 2017。改变上述语句为:
(defun tls-ado-opencon(datename / con connectionstring)
(setq connectionstring (strcat "Provider=SQLOLEDB;Data Source=DESKTOP-KREI0UP;Initial Catalog=" datename ";User ID=sa;Password=1"))
con )
其中DESKTOP-KREI0UP为我的服务器名称,账号为sa,密码为1,数据库名称为函数传递,其中filename改为dataname,这样就实现了数据库连接。
以下是其他数据库连接函数内容:
(defun tls-ado-openrs(con sql / rs)
(setq rs (vlax-create-object "ADODB.Recordset"))
(vlax-put-property rs "CursorLocation" 2)
(vlax-put-property rs "CursorType" 3)
(vla-open rs sql con nil nil nil)
rs
(defun tls-ado-getvalue(rs name)
(vlax-variant-value
(vlax-get-property
(vlax-get-property
(vlax-get-property rs "Fields")
"item"
name
"value"
(defun tls-ado-getname(rs name)
(vlax-get-property
(vlax-get-property
"item"
name
"name"
(defun tls-ado-fields->list(rs / count pcount lst curval)
(setq count (vlax-get-property (vlax-get-property rs "Fields") "Count"))
(setq pcount count)
(repeat
count
(setq curval (tls-ado-getvalue rs (setq pcount (1- pcount))))
(setq lst (cons curval lst))
(defun tls-ado-fieldnames->list(rs / count pcount lst curval)
(setq pcount count)
(repeat
count
(setq curval (tls-ado-getname rs (setq pcount (1- pcount))))
(defun tls-ado-movefirst(rs)
(vlax-invoke-method rs "movefirst")
(tls-ado-fields->list rs)
(defun tls-ado-movelast(rs)
(vlax-invoke-method rs "movelast")
(defun tls-ado-movenext(rs)
(vlax-invoke-method rs "movenext")
(if (= (vlax-get-property rs "eof") :vlax-false)
nil
(defun tls-ado-moveprevious(rs)
(vlax-invoke-method rs "moveprevious")
(if (= (vlax-get-property rs "bof") :vlax-false)
nil
(defun tls-ado-runtrans(con sql / err)
(vlax-invoke-method con "BeginTrans")
(setq err
(vl-catch-all-apply 39;vlax-invoke-method
(list con "Execute" sql nil nil)
(vlax-invoke-method con "CommitTrans")
(not (vl-catch-all-error-p err))
测试一下:
(defun C:hq()
(vl-load-com)
(setq zh0 (entsel "\n请选择井号:"))
(setq zhs (entget (car zh0)))
(setq zhg (assoc 1 zhs))
(setq zh (cdr zhg))
(setq biao "jd")
(setq con2 (tls-ado-opencon "jd"))
(setq rs2 (tls-ado-openrs con2 (strcat "select * from " biao " where jh = 39;" zh "39; order by id asc")))
(tls-ado-fields->list rs2)
(setq te (tls-ado-movefirst rs2))
(print (car te))
(print (nth 1 te)) ;片区
(print (nth 2 te)) ;井号
(print (nth 3 te)) ;井面标高
(print (nth 4 te)) ;井底标高
(print (nth 6 te)) ;Y
(print (nth 7 te)) ;井深
(print (nth 11 te)) ;
(vla-close rs2)
(vla-close con2)
(setq p0 (getpoint "选择井号的中心点:"))
(setq x (rtos (car p0) 2 4))
(setq y (rtos (cadr p0) 2 4))
(setq con (tls-ado-opencon "jd"))
(setq sql (strcat "update jd set x = 39;" x "39;, y = 39;" y "39; where pq = 39;P139; and jh =39;" zh "39;"))
(tls-ado-runtrans con sql)
(princ (strcat "已经输入" x "!"))
(vla-close con)
用hq的命令,选择一个井的井号后,点井的位置,获取x,y数值,再输入到数据库中jd表。
免费1人已点赞
CAD下载及教程
返回版块52.09 万条内容 · 690 人订阅
CAD所有特殊符号的输入方法CAD里有时候我们经常需要输入一些特殊符号,比如度数、不等于等等,以下给大家总结两种常用方法。 方法1、输入法 CAD里输入T回车,指定文字输入的位置; 一般输入法都会带一个特殊符号,点开; 找到你需要输入的符号单击即可。 方法2:CAD自带的符号 输入框中鼠标右键,选符号,选择需要的符号即可;
只看楼主 我来说两句 抢板凳上面的39;要修改为单引号。不知道为什么会这样。
