土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 工业大学:教育、办公、研究多功能建筑设计
发布于:2023-04-28 09:58:28 来自:建筑设计/公共建筑设计 [复制转发]
Nachhaltige Chemie是一座用于可持续化学研究和教育的新建筑,它扩大了Münchens工业大学Straubing校区的科学中心,形成了校区的北部入口。这座修长的三层建筑与码头平行,位于防洪墙后面和多瑙河的洪水区域内,因此用高跷抬高到离地面3米。
Nachhaltige Chemie, the new building for research and education in sustainable chemistry expands the Technische Universit?t Münchens Campus Straubing science center, forming the northern entrance to the campus. The elongated three-story building lies parallel to the quayside, behind the flood wall and within the flooding zone of the river Donau, thus elevated on stilts to 3 meters above the ground.
入口通过一层的高架平台到达,该平台跨越了洪水墙高度的大部分建筑。从这里,建筑通过中央大厅进入,这是一个由画廊和开放式楼梯组成的三层建筑。这种交流联系将建筑组织成西翼和东翼。从主体结构向河岸突出的礼堂进一步突出了建筑。
The entrance is reached via an elevated deck at the first level that spans around most of the building at the height of the flood wall. From here, the building is entered through the central hall, a three-story composition of galleries and open stairs. This communicative nexus organizes the building into a western and an eastern wing. An auditorium that protrudes from the main structure towards the riverbanks further accentuates the building.
高架的一层主要包含教育功能,上层包含办公室、研究实验室和技术工程空间。在一层,大型的、可分割的礼堂位于北部的Donau河。一层的西南部分被学生和讲师的自助餐厅占据,在主入口附近有一个户外座位区。不同大小的演讲和研讨会空间组织在建筑的西部,教育实验室,第二个小礼堂和行政办公室在东部。
While the elevated first floor mainly contains educational functions, the upper floors contain offices, research laboratories, and technical engineering spaces. On the first floor, the large, divisible auditorium is positioned towards the river Donau in the north. The southwestern part of the first floor is occupied by a cafeteria for students and lecturers with an outdoor seating area near the main entrance. Lecture- and seminar spaces of different sizes are organized within the western part of the building, educational laboratories,
While the elevated first floor mainly contains educational functions, the upper floors contain offices, research laboratories, and technical engineering spaces. On the first floor, the large, divisible auditorium is positioned towards the river Donau in the north. The southwestern part of the first floor is occupied by a cafeteria for students and lecturers with an outdoor seating area near the main entrance. Lecture- and seminar spaces of different sizes are organized within the western part of the building, educational laboratories, a second, smaller auditorium as well as administrative offices are found in the eastern part.
二楼的东部包括研究实验室,它们被规划为灵活的单元。南部的实验室有一个抬高的天花板。所有的实验室都面向外,内部区域被楼梯、技术和辅助空间占据,就像一层一样。
另一方面,二层的西侧包含了通往大型、可分割的礼堂的上层入口。办公室、休息室、会议室和其他员工空间位于二楼和三楼,围绕着西侧的庭院。三楼的东部包括电气、暖通空调和其他中央技术单元的主要房间。在建筑的第一层和甲板下面,有一个停车场,在可能发生洪水时必须清理。
The eastern part of the second floor contains research laboratories that are planned as flexible units. The southern laboratory tract has a raised ceiling. All laboratories face outwards, the inner zone is occupied by staircases, and technical and auxiliary spaces, just like on the first floor. The western part of the second floor on the other hand contains the upper entrances to the large, divisible auditorium. Offices, lounges, conference rooms, and other staff spaces are situated on the second and third floors and are grouped around a courtyard in the western wing. The eastern part of the third floor contains the main rooms for electrical, HVAC, and other central technical units. Below the building's first level and deck, there is a parking area that has to be cleared during possible flooding events.
木材、玻璃和混凝土使建筑的外墙与众不同。大部分建筑材料的来源都是可持续的。纵向外墙采用木结构,东西两侧墙体采用整体保温混凝土。部分植被覆盖的屋顶包含朝南的光伏元件。
Wood, glass, and concrete give distinction to the facades of the buildings. Most of the building materials were so   urced sustainably. The longitudinal outer walls were constructed in timber frames, the eastern and western walls are made of monolithic insulating concrete. The partially vegetated roof contains south-facing photovoltaic elements.
平面图
立面图
剖面图
建筑师:Schuster Pechtold Schmidt Architekten
地点:德国
面积:9500平方米
年份:2021
  • qq_1564129934747
    学习学习,赚点经验。
    2023-04-28 10:31:28
公共建筑设计
51.18 万条内容 · 448 人订阅
巴西校园:中小学建筑
Educar II 学校 SESC-CE 项目位于Fortaleza的 Damas社区,在一个东西纵向的场地上,尺寸约为 350.00m x 50.00m,主干道有两个正面,其三个横向通道南部。除了这些条件之外,该项目还处理了一些预先存在的条件:为当地社区服务的小教堂;将翻新并纳入学校项目的体育馆;一栋旧楼,学校的一部分已经运作,但应该拆除以建造新楼。
