The Educar II School SESC-CE project is located in the Damas neighborhood, in Fortaleza, on a longitudinal east-west site, with approximate dimensions of 350.00m by 50.00m, with two fronts for the main roads and also three transverse accesses in its southern portion. In addition to these conditions, the project also dealt with some pre-existing conditions: a chapel that serves the local community; a gymnasium to be renovated and incorporated into the school's project; and an old building where part of the school already operated but which should be demolished for the construction of the new building.
示意图
剖面图
剖面图
剖面图
With a larger area, the didactic block occupies the main access to the west and marks the entrance. From there, the internal flow is distributed to the other parts of the program, with service access taking place further south from one of the secondary accesses. This occupation of the site takes place in a porous way, creating voids that generate internal patios and marking accesses with angles that break the rigidity of the structural mesh. Meeting places emerge as a condition and guide for the distribution of the program. It is worth noting that, just as important as the built spaces are the voids created, responsible for these socializing spaces, such as the internal patio where the ramp is located, or the extensive linear park in the northern portion of the site, which unites the different sectors of the school complex.
平面图
平面图
In this sense, color also enters as a central element, helping to mark the accesses, and vertical circulations and differentiating the different parts of the program, acting as a guide within the neutrality of white that predominates in the built volume and in its apparent structure, in a space that suggests a very integrated process between architecture and visual identity. The metal structure, adapted to the limitations of the project, was designed from the 1.20m modulation and overcomes large spans, and overlapping parts for the assembly of the internal spaces, with steel deck slabs on metallic beams and honeycomb ceilings, in addition to the second skins of horizontal sunshades that protect the internal environments from direct sunlight and create a pattern for the building envelope.
平面图
Several strategies provided environmental comfort. The first is the possibility of natural ventilation in environments with vertical and horizontal circulation. In addition, the patios created brought vegetation into the building, improving air humidity, and the windows were protected by horizontal fixed metallic sunshades. Thus, the well-being of students, faculty, and staff are guaranteed by ergonomically comfortable spaces, with abundant natural light and ventilation, and reinforced by the close relationship between built spaces and green areas for socializing. The classrooms have windows on opposite walls, allowing cross ventilation and preventing the accumulation of CO2 in their internal environments.
项目信息
免费2人已点赞
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
点亮现代建筑的无名大师,理查德·凯利? Thomas Schielke 理查德·凯利(Richard Kelly)照亮了二十世纪几个最具代表性的建筑: 玻 璃屋、西格拉姆大厦和金贝尔艺术博物馆 ,等等。他的灯光设计策略出人意料地简单,但却非常成功。 玻璃屋 西格拉姆大厦 ? Flickr user: Ben Pentreath
只看楼主 我来说两句抢地板Educar II 学校 SESC-CE 项目位于Fortaleza的 Damas社区,在一个东西纵向的场地上,尺寸约为 350.00m x 50.00m,主干道有两个正面,其三个横向通道南部。除了这些条件之外,该项目还处理了一些预先存在的条件:为当地社区服务的小教堂;将翻新并纳入学校项目的体育馆;一栋旧楼,学校的一部分已经运作,但应该拆除以建造新楼。
学习学习,赚点经验。
