General DescriptionThe AP8660 is a current mode boost DC-DC converter. Its PWM circuitry with built-in 0.25Ωpower MOSFET make this regulator highly power efficient. The internal compensation network also minimizes as much as 6 external component counts. The non-inverting input of error amplifier connects to a 0.6V precision reference voltage and internal soft-start function can reduce the inrush current.The AP8660 is available in the SOT23-6L package and provides space-saving PCB for the application fields.Features? Adjustable Output up to 24V? Internal Fixed PWM frequency: 1.0MHz? Precision Feedback Reference Voltage: 0.6V (±2%)? Internal 0.25Ω, 2A, 26V Power MOSFET? Shutdown Current: 0.1μA? Over Voltage Protection? Over Temperature Protection? Adjustable Over Current Protection: 0.5A ~ 2.5A? Package: SOT23-6LApplications? Chargers? LCD Displays? Digital Cameras? Handheld Devices? Portable Products
变压器
返回版块14.15 万条内容 · 436 人订阅
DS7404B示波器DS7404B示波器 特点与优点 ·高达7.25 GHz 的有效模拟带宽和低至43 ps 的上升时间(20% 至80%) ·波形捕获速率每秒超过400,000 个,独一无二的DPX?信号采集技术 ·最大实时取样速率20 GS/s ·高超的时间变化量(Delta-time)精度可提高关键时序测量的置信度 ·强大的触发功能,可快速检测相关故障 ·达4.25 Gb/s 的通信模板测试速率
