实测 北 京某30kW非车载充电机实际运行数据,如表1所示。
表1 北 京某30kW非车载充电机实际运行数据
| 充电时长 /min | 充电电量 /kWh | 最大充电功率 /kW | 充电功率 P c /kW | Pc/Pe |
| 177 | 9.95 | 7.6 | 3.37 | 0.11 |
| 23 | 4.788 | 14.6 | 12.49 | 0.42 |
| 123 | 38.997 | 29.7 | 19.02 | 0.63 |
| 141 | 20.711 | 24.8 | 8.81 | 0.29 |
| 65 | 18.901 | 27.4 | 17.45 | 0.58 |
| 63 | 15.17 | 26 | 14.45 | 0.48 |
| 111 | 36.357 | 29.7 | 19.65 | 0.66 |
| 145 | 21.334 | 28.9 | 8.83 | 0.29 |
| 74 | 44.691 | 37.4 | 36.24 | 1.21 |
| 46 | 19.026 | 28.9 | 24.82 | 0.83 |
| 101 | 25.314 | 23.7 | 15.04 | 0.5 |
| 52 | 19.66 | 26.9 | 22.68 | 0.76 |
| 265 | 35.528 | 29.6 | 8.04 | 0.27 |
| 124 | 39.121 | 29.5 | 18.93 | 0.63 |
| 18 | 7.607 | 30.1 | 25.36 | 0.85 |
| 86 | 28.405 | 28.9 | 19.82 | 0.66 |
| 66 | 27.988 | 25.5 | 25.44 | 0.85 |
| 66 | 18.111 | 29.2 | 16.46 | 0.55 |
| 90 | 19.182 | 24.2 | 12.79 | 0.43 |
| 27 | 5.579 | 14.6 | 12.4 | 0.41 |
| 35 | 15.961 | 28.8 | 27.36 | 0.91 |
| 85 | 9.46 | 14 | 6.68 | 0.22 |
| 13 | 3.813 | 19.6 | 17.6 | 0.59 |
| 17 | 4.254 | 17 | 15.01 | 0.5 |
| 77 | 32.701 | 30.2 | 25.48 | 0.85 |
| 68 | 29.791 | 31.7 | 26.29 | 0.88 |
| 69 | 29.235 | 29 | 25.42 | 0.85 |
| 40 | 11.676 | 18.5 | 17.51 | 0.58 |
| 33 | 5.12 | 10.9 | 9.31 | 0.31 |
| 34 | 9.576 | 24 | 16.9 | 0.56 |
| 58 | 28.389 | 36.2 | 29.37 | 0.98 |
| 56 | 8.238 | 24 | 8.83 | 0.29 |
| 117 | 37.978 | 29.5 | 19.48 | 0.65 |
| 65 | 15.455 | 18.4 | 14.27 | 0.48 |
| 23 | 6.525 | 20.6 | 17.02 | 0.57 |
| 113 | 32.284 | 29.7 | 17.14 | 0.57 |
| 47 | 15.619 | 29.4 | 19.94 | 0.66 |
| 12 | 2.623 | 18.6 | 13.12 | 0.44 |
| 2 | 0.233 | 18.8 | 6.99 | 0.23 |
| 37 | 17.397 | 29.1 | 28.21 | 0.94 |
| 37 | 9.353 | 18.2 | 15.17 | 0.51 |
| 52 | 13.66 | 20.4 | 15.76 | 0.53 |
| 43 | 10.484 | 19.7 | 14.63 | 0.49 |
| 78 | 32.74 | 30.3 | 25.18 | 0.84 |
| 107 | 27.068 | 26.9 | 15.18 | 0.51 |
| 37 | 6.532 | 2.6 | 10.59 | 0.35 |
| 46 | 15.584 | 30.1 | 20.33 | 0.68 |
| 44 | 14.383 | 22.7 | 19.61 | 0.65 |
| 37 | 17.218 | 29.3 | 27.92 | 0.93 |
| 99 | 23.69 | 28.9 | 14.36 | 0.48 |
| 39 | 7.062 | 16.9 | 10.86 | 0.36 |
| 101 | 37.549 | 30.8 | 22.31 | 0.74 |
| 245 | 21.788 | 18.6 | 5.34 | 0.18 |
| 26 | 7.059 | 29.4 | 16.29 | 0.54 |
| 66 | 0 | 30.2 | 0 | 0 |
| 53 | 2.257 | 29.4 | 2.56 | 0.09 |
| 44 | 6.142 | 29.5 | 8.38 | 0.28 |
| 40 | 5.66 | 15.9 | 8.49 | 0.28 |
| 62 | 29.361 | 30.4 | 28.41 | 0.95 |
| 99 | 26.236 | 23.3 | 15.9 | 0.53 |
| 115 | 37.796 | 29.7 | 19.72 | 0.66 |
| 32 | 16.57 | 37.8 | 31.07 | 1.04 |
| 50 | 20.581 | 36.8 | 24.7 | 0.82 |
| 50 | 28.778 | 36.5 | 34.53 | 1.15 |
| 101 | 27.009 | 24.2 | 16.04 | 0.53 |
| 64 | 29.408 | 47 | 27.57 | 0.92 |
| 75 | 31.524 | 31.7 | 25.22 | 0.84 |
| 102 | 38.124 | 30.9 | 22.43 | 0.75 |
| 86 | 30.756 | 30.8 | 21.46 | 0.72 |
| 47 | 12.688 | 29.4 | 16.2 | 0.54 |
| 75 | 24.683 | 27.8 | 19.75 | 0.66 |
| 82 | 46.532 | 39.1 | 34.05 | 1.13 |
| 100 | 40.139 | 30.8 | 24.08 | 0.8 |
| 79 | 37.964 | 35.6 | 28.83 | 0.96 |
表中非车载充电 机为输入电压AC 380V/50Hz,输出为DC 60A/500V,额定功率为30kW。
Pc——实际充电功率,kW;
Pe——额定功率,此处为30kW。
从最右列可以看出,实际充电功率远小于额定功率,Pc的平均值为0.61,但是存在一定时期Pc/Pe接近1的情况。电气系统设计主要关注30min最大负荷的等效发热,以及现在电动汽车动力电池容量比以往增大较多(80kWh以上比较常见)、充电时间相对延 长。经采用SPSS数据软件分析,利用柯尔莫哥洛夫-斯米尔诺夫检验(即K-S检验)及夏皮洛-威尔克检验(S-W检验)进行正态分布分析校验, Pc/Pe ≥0.95。
图1 北 京某30kW非车载充电机实际运行数据 Pc/Pe比值
结论:单台非车载充电机的需要系数不低于0.95,工程设计时可取1。
免费2人已点赞
返回版块97.93 万条内容 · 2230 人订阅
最全电线载流量对照表电线载流量因电线规格和种类而不同,电工学习网小编将BLV绝缘电线载流量、BLX绝缘电线载流量、BV-10耐热绝缘电线载流量、BV-10耐热聚氯乙烯电线载流量、BVV/BVVB绝缘电线载流量、BV绝缘电线载流量、BX绝缘电线载流量、聚氯乙烯绝缘电线载流量、橡胶绝缘电线载流量汇总在本文,供电工学习网的朋友们使用。
只看楼主 我来说两句 抢板凳很实用的充电设计资料。收藏了。多谢分享!!!
