土木在线论坛 \ 电气工程 \ 市政公用工程 \ 自动灭火器英文资料2
自动灭火器英文资料2
发布于:2008-03-30 12:43:30 来自:电气工程/市政公用工程 [复制转发]
(Two)Auto spray water extinguish fire system and penstock water supply system.
1. tube net seep into adopt the following prevention measure:
(1)All tube net of tube material and tube the valve on the net door zero parts all should is qualified product.
(2)Tube net of worker have to hold certificate top Gang, and experienced.
(3)Such as detection seep into, should in time find out place position, drain carry on processing.
2. water current indicator(or signal Die valve) not send out report to the police signal adopt the following measure:
(1)Check water current indicator(or signal Die valve) install direction whether exactitude, model number whether in accordance with the caliber.
(2)Check water current indicator(or signal Die valve) of electric appliances component work whether normal.
3. wet type report to the police valve set not send out report to the police signal adopt the following measure:
(1)Check should valve set install way and tube road conjunction way whether exactitude.
(2)If should valve set pressure switch not report to the police, should check pressure switch of electric circuit whether normal.
(3)If should valve set of alarm bell not send out report to the police, should check alarm bell inside dish of shaft revolve whether vivid, surroundings whether cover thing.
  • zcliang_007
    zcliang_007 沙发
    慢慢看吧,找一本字典放在手上,还是可以的。。。:lol
    2008-10-21 21:22:21
市政公用工程
3.11 万条内容 · 202 人订阅
有关自动灭火器英文资料1
Auto extinguish fire system quality common failing and defend way (A)A fire auto report to the police and fire fight allied move control system1.under construction pipeline spread establish break head, little line, connect ground, short circuit hour should adopt the following measure defend Ye:
