土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 普通混凝土结构台阶
普通混凝土结构台阶
发布于:2022-08-17 14:16:17 来自:建筑结构/混凝土结构 [复制转发]
台阶数最少不能低于多少个呀请问。
140.17 万条内容 · 2232 人订阅
千层式分割型:公寓设计
NUBE建筑是由Jacobsen Arquitetura设计和建造的第一座住宅塔楼。与之前的项目不同,在之前的项目中,我们将立面和室内设计的概念应用到现有的结构中,在NUBE建筑中,我们有机会从一开始就在位于S?o Paulo市的Itaim Bibi地区工作。 The NUBE building was the first residential tower designed and built by Jacobsen Arquitetura. Unlike previous projects, in which we adapted the facades and interior design concepts to existent structures, in the NUBE building, we had the opportunity to work, from the beginning, on the occupation of the area located in Itaim Bibi, a neighborhood in the city of S?o Paulo, Brazil.
