土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 千层式分割型:公寓设计
千层式分割型:公寓设计
发布于:2022-08-17 11:30:17 来自:建筑结构/混凝土结构 [复制转发]
NUBE建筑是由Jacobsen Arquitetura设计和建造的第一座住宅塔楼。与之前的项目不同,在之前的项目中,我们将立面和室内设计的概念应用到现有的结构中,在NUBE建筑中,我们有机会从一开始就在位于S?o Paulo市的Itaim Bibi地区工作。
The NUBE building was the first residential tower designed and built by Jacobsen Arquitetura. Unlike previous projects, in which we adapted the facades and interior design concepts to existent structures, in the NUBE building, we had the opportunity to work, from the beginning, on the occupation of the area located in Itaim Bibi, a neighborhood in the city of S?o Paulo, Brazil.
在这个项目中,我们打算重新诠释工作室设计的住宅中的建筑概念。在每间公寓中,我们的目标是营造一种住在单层房子里的感觉。作为建筑设计的一部分,我们试图从一个巨大的空旷空间中勾勒出 Jardins 住宅区的壮丽和畅通无阻的景观,公寓围绕着该空间布置,其植物是 L 形的。每间公寓的社交区域都面临着从地板到天花板的框架观察到的特权景观。套房面向对面,服务区在后面。
In this project, we intended to reinterpret architectural concepts present in the residences designed by the studio. In each apartment, we aimed to create a feeling of living in a one-story house. As part of the architectural design, we sought to frame a magnificent and unimpeded view of the Jardins residential district from a large empty space, around which the apartments were arranged, whose plants are L-shaped. The social areas of each apartment face a privileged view, observed from floor-to-ceiling frames. The suites face the opposite side and the service areas to the back.
每一层都水平标记了延伸的屋檐,有助于建筑物的隐私和防晒。对于其他立面,设计了垂直改性木质遮阳板,这是一种可持续的解决方案,具有良好的耐候性。与围栏分离的建筑结构由圆形截面的柱子组成。
Each floor has been horizontally marked for extended eaves, contributing to the building's privacy and sun protection. For the other facades, vertical modified wood brise-soleils were designed, a sustainable solution that offers good weather ability. The building structure, detached from the fence, is composed of pillars of circular sections.
该塔楼有15层,最后三层是一个大型的三合院单位,在两个复式公寓之上。一个大花园将街道与主入口连接起来,特意将其向后移。要进入该建筑,必须穿过一座愉快的木桥,由建筑的突出部分保护。花坛分布在不同的楼层,在一楼,有助于传递出更大的幅度的印象。在一楼,它是一个有盖的游泳池、休息室、桑拿和其他技术区域的地方,周围的石头,界定了露台。
The tower has fifteen floors, the last three floors being occupied by a large triplex unit, on top of two duplex apartments. A large garden connects the street to the main entrance, purposefully set back. To access the building, it is necessary to cross a pleasant wooden bridge, protected by the projection of the building. The distribution of flowerbeds on different levels, on the ground floor, contributes to transmitting the impression of greater amplitude. On the first floor, it is a place for a covered swimming pool, lounge, sauna, and other technical areas, surrounded by exposed stones that define the terrace.
平面图
剖面图
细部节点
建筑师:Jacobsen Architecture
地点:巴西
面积:5130平方米
年份:2021
140.17 万条内容 · 2229 人订阅
庄园酒店 | 简洁精致:逐层退台的设计手法,形成了丰富的层次……
归来兮桠溪庄园酒店 综合接待中心 建识(北京)设计咨询有限公司 ● “错落层叠”的场地策略 ● “双面”的体量设计 ● 水平延展的立面 ● 在地化的材料选择 ● 简洁精致的构造 01 BACKTO慢城 | 远心生活
