土木在线论坛 \ 建筑结构 \ 砖混结构 \ 板条立面设计:创造了一种有节奏的阴影效果
发布于:2022-08-10 10:59:10 来自:建筑结构/砖混结构 [复制转发]
该项目是基于对一个特定的集体住房项目的回应。该地块位于Aveiro市新区的一个分区,位于两个尚未建成的地块之间。因此,项目的理念是在这个新的领域标记一个新设计的亮点。
The project is based on responding to a specific collective housing program. Inserted in a subdivision located in the new area of Aveiro city, the land is located between two lots, which are not built yet. As such, the project idea is based on marking the highlight of a new design in this new area.
该项目打算充分利用这个地方的特点,如景观和阳光照射。拟建的体量由板条设计组成,能够将内部空间向外部延伸,同时,在项目设计中,将该地的地平线人格化。其混凝土的原始材料旨在强调其不羁的个性。玻璃,除了在其与外部的关系中打算在空间中创造透明度外,还打算给混凝土的固体水平元素以轻盈的设计。
The project intends to take full advantage of the characteristics of the place, such as views and sun exposure. The proposed volume is composed of a slatted design to be able to ex- tend the interior space to the exterior, and, at the same time, personify the horizon line present in the place in the project design. Its raw materiality in concrete intends to emphasize its irreverent personality. The glass, in addition to the transparency that it intends to create in the spaces in its relationship with the outside, intends to give the solid horizontal elements of concrete the design of lightness.
城市中心现有的运动在外墙上的叶片中是可见的。这些,除了在需要的时候给住宅内部提供隐私外,还创造了一种有节奏的阴影效果,给建筑带来了运动和不断变化的理念。
The existing movement in the city center is visible in the blades present on the facade. These, in addition to giving privacy to the interior of the dwellings when desired, create a rhythmic effect of shadows that transcribe to the building an idea of movement and constant transformation.
进入建筑的通道从两个主要入口开发。房屋内部空间的配置包括将社会空间置于前台,并保留私人空间的庇护和隐私。
Access to the building is developed from two main entrances. The configuration of the interior space of the house involves placing the social space in the foreground and preserving the refuge and privacy of the private space.
建筑师:Mário Alves architect
地点:葡萄牙
面积:3277平方米
年份:2021
砖混结构
10.11 万条内容 · 458 人订阅
干货丨砖砌围墙结构设计
砖砌围墙是项目中频繁出现的设计内容,它是一个构筑物,不能按房屋建筑的结构设计流程那样建模、计算、出施工图,给许多年轻设计师带来困惑。 砖砌围墙设计要注意哪些问题,要做哪些结构计算呢? 下面,我们用一个普通粘土砖砌体实心围墙(未考虑围墙中扶壁柱的影响)为例,讲述围墙设计要注意的问题和结构计算的内容。 一、围墙平面布置
