土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ CAD多线段的线宽显示正常,但是直线线宽不显示,怎么办?
发布于:2022-07-04 13:26:04 来自:建筑设计/公共建筑设计 [复制转发]
文|CAD自学网,作者:摩尔
问:多线段的线宽显示正常,但是直线线宽不显示,怎么办?
答:
多线段的线宽显示与直线线宽的显示,控制变量不是同一个,所以会出现多线段线宽显示正常,但是直线的不显示。
多线段的线宽是fill命令控制,on是显示,off是不显示。
控制直线线宽显示的命令是lwdisplay,0不显示,1显示。
公共建筑设计
51.18 万条内容 · 448 人订阅
流畅的流线型体:西港2号码头
转自公众号:PES Architects 由PES建筑事务所设计的西港2号码头,位于赫尔辛基港西岸新货运港区J?tk?saari附近的一块狭长场地上。新码头的建造是为满足赫尔辛基至塔林航线上不断增长的渡轮客流量需求。设计旨在提升乘客上下船的速度,并将港口渡轮的周转时间缩短至1小时。新码头每年将容纳超过六至七百万往返于赫尔辛基和塔林的游客。 PES-Architects’ West Terminal 2 (L?nsiterminaali 2), completed in February 2017, is situated in Helsinki's West Harbour on a narrow plot of reclaimed land at the southern tip of the new J?tk?saari neighbourhood, a former freight port area. The new terminal was built to meet the needs of the growing ferry traffic on the Helsinki-Tallinn route. The goal was to enable faster embarkation and disembarkation of passengers and reduce the turnaround times of ferries in port to just one hour. The terminal will serve the majority of the 6-7 million passengers travelling between Helsinki and Tallinn via West Harbour each year.
