土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 冰晶盒子——北京亚运村街道办事处改造
冰晶盒子——北京亚运村街道办事处改造
发布于:2022-05-25 09:35:25 来自:建筑结构/混凝土结构 [复制转发]
冰晶盒子,亚运村街道办事处改造
中国建筑设计研究院
▲  路口对面
如何以微更新、点激活的方式来唤醒整个街区?如何让街角承载更多的活力?经过反复规划与多轮的艰苦谈判,最终决定将这里改造成亚运村街道社区办事处,塑造服务于民的冬奥之家,塑造北京最美网红社区办事处,以桥头堡的位置昭示着亚运村街道勇于蜕变的坚定信心!
让老展厅变废为宝,以低造价、轻介入、易施工的方式实现街角的华丽转身,不再是传统的、门脸房式的、窗口大厅的街道办事处,而是让老百姓能走进来、看得见、乐参与的新时代社区生活中心!
How to wake up the whole community by micro-updates or a catalyst is the key point. And then next is how to make the street corner bring more energy. After a long time of carefully planning and rounds of tough negotiations, an Asian Games Village neighborhood community office was finally decided to transform this place into, construct a Winter Olympic home for the people, and build a beautiful community office for Beijing. Its position serves as a start point to show the courage to change! The old exhibition hall should be changed into a brand new building, which is a gorgeous turn of the street corner, by the means of low cost, light intervention, and easy construction. It would no longer be the traditional street office of gatehouse style and window hall, but the center of community life in the new era, where the people can come in, see inside, and participate happily!
▲  改造以前
▲  改造过程
▲  前后对比
由于资金有限,不能再采用昂贵的幕墙,而便宜的铝合金门窗系统框料过于憨笨,这个街角的位置又十分重要需要惊艳的美,而原有结构又不能支撑太重的外墙或幕墙,这些问题让外立面的设计步履维艰。既然不能用幕墙,索性将视线转向的砖,因为砖和北京的乡土文化渊源深厚。
但是,砖筑是浑厚的、沉重的,原有的结构显然难以支撑砖墙的依靠!我们需要一种轻盈的,最好是透明的,而且不太贵易于施工的砖。于是我们想到了用有机玻璃来自己造砖。既然自己造砖,材料中便可以植入我们想要的“色卡”,可以给这个沉闷的街口一点“颜色”!而我们选择了白色,因为冰雪,因为冬奥,像冰雪一样晶莹剔透的砖!
Instead of an expensive curtain walls system, an aluminum alloy door and window system should be used due to the limited funds, which are not slim or exquisite. however, the location of this street corner is quite important, which needs an amazing brilliant view!And, the original structure cannot support such heavy exterior walls or curtain walls, which makes the decision of exterior facade martial very difficult. Since the curtain wall cannot be used, attention is paid to the brick, which has a deep origin in the local culture of Beijing. However, the bricks are weighty, and are too heavy to be supported by the original structure!More light, preferably transparent, inexpensive, and easy to construct materials is needed. So we thought of using plexiglass to make bricks by ourselves. Since we make bricks by ourselves, the "color card" can be put inside, which can give more "color" to the old street! Finally, kinds of white are chosen for the color of ice and snow, and also for the Winter Olympics!
▲  人行路上
▲  落雪2022
▲  西立面
在业主和施工方的大力支持下,我们用透明亚克力,不透明亚克力,透明阳光板,不透明阳光板,4种材料组合制造了5种砖块,并且制作了小样。安装方式也借鉴了砌块墙穿筋的方式,每块砖上开了两个小洞,用以错缝穿筋。数千块冰砖和雪砖,从天空中飘落,落在用不锈钢制作的2022雕塑上,形成了飘雪的2022!而2022四个数字也支撑起了这个建筑的门洞,人们通过2022,走进2022,开启新时代的美好生活!
With the support of the sponsor and the construction team, we have made 5 kinds of bricks with 4 kinds of materials: transparent acrylic, opaque acrylic, transparent sunshine board, and opaque sunshine board, and made small samples. The installation method also follows the way of threading reinforcement of brick walls. Two small holes are opened on each brick to thread reinforcement at staggered joints. Thousands of ice and snow bricks fall from the sky and finally lay on the 2022 sculpture made of stainless steel, forming an ice and snow 2022! The four numbers of 2022 also support the door of this building. People enter 2022 through 2022 and open a better life in a new era!
▲  双奥标志
▲  北立面
走进2022,你便进入了这个建筑,一层是开放的大厅,透明的圆曲玻璃将室内外融合在一起。进入大门,右手边是社区接待台与导览。正对着的是旋转的木门,闭合时形成走廊,开启时成为社区展板与宣传栏。左手边是开敞的大厅,2022的0对应着街角,也形成了0舞台,社区居民可以在此议事、宣讲、也可以表演节目,当然,这些节目外面的路人都可以看到,亦可加入进来。在最里面是图书角,小朋友们可以在此看书学习。
By 2022, you enter the building. On the first floor is an open hall, and the transparent round glass integrates the indoor and outdoor. Entering the gate, on the right is the community reception desk and guide. Facing the revolving wooden door, it forms a corridor when closed and becomes a community exhibition board and billboard when opened. On the left is an open hall. 0 in 2022 corresponds to the street corner and forms a 0 stage. Community residents can discuss, preach and perform programs here. Of course, passers-by outside these programs can see and join in. At the bottom is the book corner, where children can read and study.
▲  外廊与内透
▲  安定路旁
▲  主入口
利用原有改的楼梯步入二层,在此进入一个雪白的世界,这里营造了一间会议室和一间公共活动的多功能厅,从多功能厅看出去,是0的上方,如同东南向升起的太阳,让社区每天都彰显着希望!
Through the original modified stairs, you can enter the second floor, a snow-white world here. A conference room and a multi-functional hall for public activities are built here. From the multi-functional hall, it is above the 0, which looks like the rising sun in the southeast, which makes the community gain wishes every day!
▲  转角
▲  北侧落地窗
▲  内外之间
▲  小舞台
▲  展廊空间
▲  二层多功能厅
▲  LOGO(向刚)
▲  北立面图
▲  西北透视图
▲  1层平面图
▲ 2层平面图
面积 : 500 m2
项目年份 : 2021
摄影师 :向刚
主创建筑师 : 郭海鞍
规划团队 : 唐燕、李婧、齐梦楠
设计团队 : 向刚、郑传颖、孙青峰、程帝、杜媛媛
合作方 : 北京世纪千府国际工程设计有限公司
照明设计 : 宁之境
施工方 : 北京京西建设集团有限责任公司
地点 : 中国 北京
140.17 万条内容 · 2232 人订阅
三校合一的高中园区设计:突破传统限制,复合功能、单元模块式教学组团策略
云谷·浮城 光明高中园综合高中 同济大学建筑设计研究院 0. 楔子  | 在周边高密度建筑森林的背景下,营造一座云谷·浮城,为学生提供具有领域感的私密场所,还园区和城市一片共享绿色。 东南 角鸟瞰效果图 东南角街景效果图 总平面图  1. 缘起 |
