土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 极简现代混凝土外观
极简现代混凝土外观
发布于:2022-05-17 09:07:17 来自:建筑结构/混凝土结构 [复制转发]
场地是该项目概念背后的驱动力。开发一个有两条街的仓库,同时保留第三条街的立面,以体现雅瑞德总部的企业形象。
The site was the driving force behind the concept of the project. Developing a warehouse with 2 streets’ access while ke eping the 3rd street fa?ade for the corporate image of the Yared Headquarters.
仓库建筑的围护结构来源于每个空间的功能。集装箱将从较低的街道上装卸沉重的钢材,而较小的卡车将负责从较高街道上装卸重量较低的商品。在室内,天花板的高度也来源于空间的主题,例如,地面层的吊车是空间的独裁者。最优的功能是我们对体量最初想法的出发点和结果。
The warehouse building’s envelope derives from the function of each space. Containers would be loading and unloading heavy masses of steel from the lower street whereas smaller trucks would be taking care of the low-weighted merchandise from the upper street. Inside, the ceilings’ heights also derive from the subjects in the space, for instance, the overhead cranes at the ground floor are the dictator of the space. Optimal functionality is the starting point and result of our initial idea of the volume.
处理现场现有的混凝土结构,帮助我们从其中找到了容纳办公室的混凝土体积。北面的玻璃幕墙,自然采光,我们增加了一个标志性的标语,以增强雅瑞德的企业形象。
Dealing with an existing concrete structure on-site helped us emerge from it the concrete volume housing the offices. With a Northern glass fa?ade, naturally lit, we added a signature-louvers to empower the corporate image of Yared.
仓库在混凝土地板上的钢结构中完成,以最大化功能、所需的体积(高度)、建设速度和效率。在办公室的混凝土屋顶上,坐落着最美丽的游泳池,就像蛋糕上的樱桃一样,为他们的企业晚宴、社会筹款活动和休闲午餐提供食物。
The warehouse is done in a steel structure atop concrete floor, for maximizing functionality, needed volume (height) and construction speed and efficiency. As a cherry on top of a cake, lies the most beautiful pool on the concrete roof of the offices to cater for their corporate dinners, social fundraisers and casual lunch breaks.
平面图
立面图
剖面图
细部构造
建筑师:Atelier130
地点:黎巴嫩
面积:10000平方米
年份:2020
140.17 万条内容 · 2232 人订阅
能帮你省时、省成本的碳纤维胶厂家是什么样?工程人都想了解
有一位客户在咨询过程中曾提到这样一个问题:碳纤维加固步骤较多,有没有一款碳纤维胶能帮助加固施工省时、省工、省成本呢?答案是有的,就是选用优质的碳纤维胶。那么,什么样的碳纤维胶厂家才能做到呢?我们就要从不同的厂家生产的碳纤维胶中去寻找答案。 通过多年的加固施工经验,好的碳纤维胶厂家对胶的品质只会有着更加严格的标准。 首先,碳纤维胶质量必须满足现行国家标准GB 50728-2011《工程结构加固材料安全性鉴定规范》。其次,胶的温度适应性广,具备较好的触变性,易操作,易涂刷,无流淌,环保、无毒、无乙二胺。然后,胶体浸润性要好,能充分浸润碳纤维布,同时能节约用胶量,可为用户节省一部分的经济成本。
