The N5172B is a 6 GHz RF Generator from Agilent. An RF generator is a tool engineers use to generate sinusoidal outputs while testing electronic equipment. The output will automatically have its frequency varied or swept between frequencies. A “sweep” is one complete cycle of a frequency variation. Engineers use RF signal generators as test equipment, mostly to measure responses of filters, amplifiers, and electrical components.
Additional Features:
9 kHz to 3 or 6 GHz
+21 dBm specified power to 3 GHz with electronic attenuator
< 900-?s simultaneous switching of frequency, power, and waveform type
≤ -73 dBc ACP W-CDMA 64 DPCH and <0.4% EVM 80 MHz 802.11 AC
AM, FM, ?M, and narrow pulse
10 MHz multifunction generator and LF out
Digital step and list sweep modes
l/Q modulation: ASK, FSK, MSK, PSK, QAM, custom I/Q
120 MHz internal baseband generator (±0.2 dB flatness): arbitrary waveform and real-time I/Q
512 Msample playback memory and 30 GB internal or 8 GB external, removable memory
Arbitrary and real-time signals: LTE, HSPA+, WLAN, GNSS, DVB, and more – Signal Creation
Multi-channel baseband generation with Agilent HP N5102A digital I/O, MIMO, and RF fading with PXB
1000BaseT LAN, LXI, USB 2.0, and GPIB
SCPI, IVI-COM, MATLAB drivers
Backward compatible with ESG, MXG, PSG and 8648x signal generators
Agilent HP USB power sensor compatible with embedded display and SCPI control
Maximize yield with outstanding hardware performance
Confidently test components with industry-leading ACPR, EVM, and output power
Maximize throughput with fast switching speed
Shrink your test stand with two rack-unit height
Test a broad range of signals with the most sophisticated applications
Support multiple technologies for cellular, wireless connectivity, video, and tracking/navigation applications with Signal Studio software
Simulate real-world signals with real-time capabilities for LTE, GNSS, DVB, and more
Increase uptime with high mean time between failures (MTBF) based on first-generation MXG track record
Minimize downtime and expenses with self-maintenance strategy and low-cost repairs
To help you achieve faster throughput and greater uptime, the Agilent N5172B EXG is optimized for manufacturing test with the signals you’ll need for basic parametric testing of components and functional verification of receivers.
工业自动化
返回版块17.93 万条内容 · 389 人订阅
变频器在清灰时需要注意的事项变频器在实际运作过程中,总是会受到所处使用环境的影响,例如温度、湿度、空气质量等。生产车间里难免有各种细微的灰尘浮动,我们肉眼是难以察觉的,如果企业相关管理员平时不注意对变频器进行清洁保养的工作,过一段时间就会发现变频器上面会堆积一些灰尘,特别是顶部和角落的地方。如果不及时清理灰尘,则会对变频器的运行有一定的影响,严重些还会产生一些故障问题。那么企业相关管理员在变频器清理灰尘的过程中需要注意什么呢?下面为大家具体介绍一下:
