土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 花园式外立面:办公大楼
花园式外立面:办公大楼
发布于:2022-05-11 09:23:11 来自:建筑结构/钢结构工程 [复制转发]
惠普大厦位于北宁省人口密集的地区。该项目面积为440平方米(20.9米x 21.1米),主立面位于西北部。业主希望生活空间与自然紧密相连,充分利用自然光线,并有充足的休息空间。此外,独特的外观是业主的要求之一。
HP Building is located in a densely populated area in Bac Ninh province. The project has an area of  440m2 (20.9m x 21.1m) and the main facade to the northwest. The owner expects a living space that closely connects to nature, makes the most of natural light and has plenty of resting space. Moreover, a unique and distinctive fa?ade is one of the owner’s requirements.
由于该房屋的外墙朝西,且靠近主干道,我们需要找到一个解决方案,不仅有助于创造一个独特的外墙,还能确保内部空间不受直接自然阳光的影响,扩大视野,并将周围车辆的灰尘和噪音降到最低。该房屋的主要功能包括疫苗接种中心(1楼)、水疗中心(2楼)、出租房(3、4、5楼)和咖啡馆(6楼)。
外墙由数百个高架花园床组成,以不同的高度排列,形成一个巨大的绿化层。这个解决方案有助于为房子创造独特性,使自然光更好地分布到内部空间,更好的视野,更有效地防止来自外部的灰尘和噪音。
As the house has a west-facing facade and is situated close to the main road, we need to find a solution that not only helps create a unique facade but also ensures that the interior space is not affected by direct natural sunlight, the visibility is expanded and the dust and noise from surrounding vehicles are minimized. The main functions of the house include a vaccination center (1st floor), a spa (2nd floor), rooms for rent (3rd, 4th, 5th floor), and a café (6th floor). The facade is made up of hundreds of raised garden beds arranged at different heights, creating a giant layer of greenery. This solution helps to create uniqueness for the house with better distribution of natural light to the interior space, better visibility and more effective prevention of dust and noise from outside.
主大厅的一个大空隙直接连接到房子中间的中庭,这有助于人们走进室内时带来舒适的感觉。空间和中庭直接与楼梯和电梯相连,便于人们的观察和移动。此外,这也是一个解决方案,有助于通风和获得更好的自然光线的房子的中间区域。人们在楼层之间走动,到处都能感受到绿色植物和自然光。
A large void in the main lobby is directly linked to the atrium in the middle of the house, which helps bring a comfortable feeling when people step inside. The void and the atrium are directly connected to the stairs and the elevator to help people easily observe and move. In addition, this is also a solution to help ventilate and get better natural light for the middle area of the house. People moving between floors can feel the greenery and natural light everywhere.
六层作为室外花园,创造缓冲空间,有助于提高室内空间质量。这里用大树来冷却室内空间,限制噪音,并允许自然通风进入房子。HH建筑是克服朝西住宅局限性的实用解决方案的组合,我们专注于创造更多的休息空间,增加通风和自然光线,提高室内生活空间的质量,并为该地区的人们激发绿色生活。
The 6th floor is used as an outdoor garden to create buffer spaces, which helps improve the quality of the indoor space. Large trees are used here to cool the indoor space, limit noise and allow natural ventilation into the house.HH Building is a combination of practical solutions to overcome the limitations of the west-facing house, in which we focus on creating more resting spaces, increasing ventilation and natural light, improving the quality of indoor living space and inspiring green living for people in the area.
区位图
平面图
立面图
剖面图
建筑师:Kien Truc NDT
地点:越南
面积:440平方米
年份:2021
  • ppcool998
    ppcool998 沙发
    感谢楼主的分享的资料。学习了
    2022-05-11 10:03:11
钢结构工程
46.53 万条内容 · 1223 人订阅
钢丝绳绳夹数量、间距和方向的规范要求,值得收藏!
      在施工现场主要的应用场景:起重吊装机械吊绳、型钢挑架卸荷钢丝绳、悬挑式操作平台等。那么在不同的应用部位,对于钢丝绳直径、绳夹数量、间距、方向是如何规定的? 一、型钢悬挑脚手架     《建筑施工扣件式钢管脚手架安全技术规范》(JGJ130-2011)中6.10条相关条文说明:
