土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 玻璃幕墙立面:办公建筑
玻璃幕墙立面:办公建筑
发布于:2022-05-07 14:11:07 来自:建筑结构/钢结构工程 [复制转发]
外墙的透明和不透明的交替提供了保护和感知外部空间的双重功能。一片玻璃和钢的叶片,像一个指向西北的船头,作为埃森哲人才中心大楼建筑构成的支点,这是埃森哲在意大利的办事处之一,是Park Associati为Milanofiori Sviluppo(Gruppo Brioschi Sviluppo Immobiliare)设计的项目。
The alternation of transparency and opacity on the fa?ade provides the double function of protection and perception of the external space. A blade of glass and steel, resembling a prow pointing north-west, acts as the fulcrum of the Accenture People Hub building’s architectural composition, one of Accenture39;s offices in Italy, a project by Park Associati for Milanofiori Sviluppo (Gruppo Brioschi Sviluppo Immobiliare).
该建筑地上有15层,占地面积约31,500平方米,是Assago Milanofiori Nord区的最显著成就之一。该建筑群的两个立面从建筑的 "前端 "开始发展。面向高速公路的最大、最高的建筑体的特点是垂直元素和水平弦线的紧密连接,打破了其统一的玻璃表面。突出西南方向立面的玻璃尖顶具有一个透明的一面和一个磨砂的一面,提供了对太阳辐射的保护。
Comprising fifteen floors above ground and covering a surface of approximately 31,500 square meters, this building is one of the most notable achievements of the Milanofiori Nord sector in Assago. The two fa?ades of the complex develop from the building’s ‘prow’. The largest, tallest body facing the motorway is characterized by a tight succession of vertical elements and horizontal string courses that break up its uniform glass surface. The glazed cusps that punctuate the southwest-facing fa?ade feature one transparent side and a frosted one that offers protection against solar radiation.
建筑朝北的较短立面俯瞰树林,全是玻璃,因此提供了最大的透明度;它允许更大的渗透性,增加了建筑与周围环境的关系。对自然空间的感知是尽可能的直接。该建筑从一个基地升起,下面是两个地下停车层。创造一个几何空间,从这里可以看到周围所有的建筑,在建筑入口处开发的新空中广场与附近的地铁站相连。
The building39;s shorter north-facing fa?ade overlooking the wood is entirely glazed, therefore offering maximum transparency; its exposure allows for greater permeability and increases the building’s relationship with the surrounding environment. The perception of the natural space is as direct as possible. The building rises from a base below which are two underground parking floors. Creating a geometric space from which all surrounding buildings can be seen, the new aerial square developed at the building’s entrance is linked to the nearby Underground station.
从较高的楼层,一系列连续的空间通向双层高的门廊通道,使人们可以进入建筑。大厅作为外部广场、木材和建筑内部之间感知联系的元素。由于建筑外部和内部材料的连续性,大厅变成了一个有覆盖的广场,聚集和传递所有复杂的人流,同时容纳了大多数公共功能——培训区、门厅和自助餐厅。
From the elevated level, a series of successive spaces leads to a double-height porticoed passage that gives access to the building. The hall acts as an element of perceptive connection between the outside square, the wood, and the inside of the building. Thanks to material continuity between the building’s outside and inside, the hall is turned into a covered square that gathers and conveys all the complex’ flows, as well as housing most communal functions – the training area, foyer, and cafeteria.
底层和第一层为建筑的基础提供了形状,而建筑则从这里升起。与主立面相比,外部表面使这部分具有更多的纹理和内向特征。朝着地铁站的方向,由底层和一楼组成的基地具有更多的纹理和内向的外墙,保护培训区和会议室免受噪音影响。位于高层的办公室将具有不同大小和功能的空间,可容纳3800人。位于顶层的空中酒吧将是一个放松的地方,提供周围景观的美妙景色。
The ground and first floors give shape to the base from which the building rises. The outside surface lends this section a more textured and inward-looking characteristic than the main fa?ades. Facing in the direction of the underground station, the base comprising the ground floor and the first floor features a more textured and inward-looking fa?ade that protects the training areas and meeting rooms from noise. Located on the upper floors, the offices will feature spaces of different sizes and functions that will house up to 3,800 people. The sky bar on the top floor will be a relaxing place offering a wonderful view of the surrounding landscape.
平面图
立面图
剖面图
建筑师:Park Associati
地点:意大利
面积:31500平方米
年份:2022
钢结构工程
46.53 万条内容 · 1223 人订阅
世茂深港国际中心天环结构振动舒适度设计
摘要: “天环”位于世茂深港国际中心商业综合体的裙房七层,作为项目特色亮点区域,将与餐饮、观光、展览、舞台等功能相结合,带动项目乃至片区的商业活力。“天环”结构水平弧形外伸,悬挑跨度为28.5m,悬挑段总长度为59.6m,采用顶部巨型箱梁吊挂的结构形式。“天环”的竖向一阶自振频率为1.88Hz,使得人致振动舒适度问题成为结构设计的控制要素。从适用标准、参数取值、人致荷载的选取及工况模拟等方面详细分析了“天环”的振动舒适度性能,提出了采用TMD装置满足舒适度要求的方案,并给出了减振装置的设计参数。文中分析方法和成果可供类似的吊挂型长悬挑钢结构借鉴和参考。
