土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 线性图案的立面——韩国办公大厦
线性图案的立面——韩国办公大厦
发布于:2022-04-24 15:57:24 来自:建筑结构/混凝土结构 [复制转发]
兴国大厦位于韩国人口第二多的城市釜山,作为办公楼,毗邻海岸线,靠近城市的高铁网络。
Located in South Korea’s second-most populous city Busan, the Heungkuk Tower serves as an office building and sits adjacent to the coa stline and close to the city’s high-speed rail network.
该建筑的显着特点是其鲜明的黑色和紫红色的各种线性图案的立面。框架的作用超越了装饰,不断创造不同的氛围,过滤入射光,并在室内空间形成阴影。最大化土地分配,这座建筑优雅地坐落在城市密集的建筑区。
The building’s distinguishing feature is its stark black and fuchsia facade of various linear patterns. The role of the frame extends beyond decoration, continuously creating different atmospheres, filtering incoming light, and making shadows across the interior spaces. Maximizing the land allocation, the building sits elegantly in a densely built-up area of the city.
建筑与周围环境的关系反映了时间的流逝,从白天到夜晚都在变化。当建筑从内部发光时,其独特的立面图案向周围环境展示。
The relationship between the building and its surroundings reflects the passing of time, changing from day to night. As the building glows from within, its characteristic facade pattern is revealed to the surroundings.
位于大楼内的公司的员工和访客可以利用屋顶花园作为休息区和环境,可以看到港口和周边地区的景色。
Employees and visitors of the companies housed in the building can make use of the roof garden as an area to retreat and an environment offering views into the port and surrounding district.
平面图
立面图
建筑师:Mecanoo
地点:韩国
面积:20000平方米
年份:2020
  • 山河边城
    山河边城 沙发
    2022-04-24 16:49:24
140.17 万条内容 · 2232 人订阅
简约现代,校园办公楼
由于发展迅速,独角兽IT公司Infobip委托在萨格勒布建造了一座新的混合建筑。该该公司选择了萨格勒布南部边缘的一个位置,该位置在基础设施方面连接良好。该地块位于一个熵控且管理不善的区域,低层中等密度的多住宅建筑缺乏铰接式公共空间和自然环境。 Due to its rapid growth, the unicorn IT company Infobip commissioned a new hybrid building in Zagreb. The company chose a location on the southern edge of Zagreb that is well connected in terms of infrastructure. T
