土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 简约现代,校园办公楼
简约现代,校园办公楼
发布于:2022-04-24 15:57:24 来自:建筑结构/混凝土结构 [复制转发]
由于发展迅速,独角兽IT公司Infobip委托在萨格勒布建造了一座新的混合建筑。该该公司选择了萨格勒布南部边缘的一个位置,该位置在基础设施方面连接良好。该地块位于一个熵控且管理不善的区域,低层中等密度的多住宅建筑缺乏铰接式公共空间和自然环境。
Due to its rapid growth, the unicorn IT company Infobip commissioned a new hybrid building in Zagreb. The company chose a location on the southern edge of Zagreb that is well connected in terms of infrastructure. T he plot is located in an entropic and poorly regulated area with low-rise medium-density multi-dwelling buildings lacking both articulated public space and natural surroundings.
这个拥有高素质员工的著名投资者园区必须弥补这些缺点,这就是为什么建筑被设计成一个自给自足的有机体,为员工提供他们在工作日和以后需要的一切。投资者要求为员工和客人创建住宅区域,以及其他配套设施,如会议厅和娱乐空间。项目的混合特性导致了空间和程序元素相互叠加的概念。
This prestigious investor’s campus with highly qualified employees had to compensate for these shortcomings, which is why the building is designed as a self-sufficient organism that provides its employees with everything they need during the workday, and beyond. The investor requested that a residential section be created for employees and guests, as well as other accompanying facilities such as a conference hall and recreation spaces. The hybrid character of the project has led to the concept of stacking the spatial and program elements on top of each other.
建筑物的底部是聚集在中央中庭周围的办公室,顶部细长的垂直块是住宅单元。过渡层在建筑的空间组织中起着关键作用。底层有一个开放的车库和入口,是基于 "开车进入 "办公室的想法,这是由郊区的背景所决定的。
位于四楼的 "Piano nobile",设有餐厅、会议厅和一个大型露台公园,连接了基地和垂直街区。它是一个休息和非正式聚会的场所,也是建筑的永久用户和临时用户之间的联系。这系统地反映了建筑横断面上不同的城市、程序和社会景观之间的过渡情景。
The base of the building contains offices gathered around a central atrium, and the slender vertical block on top of it houses the residential units. Transitional floors play a key role in the building's spatial organization. The ground floor, with an open garage and entrance, is based on the idea of a “drive-in” office, necessitated by the suburban context. The "piano nobile" on the 4th floor, featuring a restaurant, conference hall, and a large terrace park, connects the base and the vertical block. It is a place of rest and informal gatherings and a link between the permanent and temporary users of the building. This systematically reflects the scenario of the transition between the different urban, programmatic, and social landscapes in the cross-section of the building.
所有的建筑元素都是精心协调的,而建筑的结构和基础设施作为建筑内部和外部设计的一部分被明确地暴露出来。该建筑显然作为一个空间和技术的有机体,是完整的,展示了 "功能和概念的透明度"。
All of the constructive elements are carefully coordinated, while the structure and infrastructure of the building are explicitly laid bare as part of the building's interior and exterior design. The building clearly functions as a spatial and technological organism that is complete unto itself, demonstrating a "functional and conceptual transparency".
区位图
平面图
立面图
剖面图
建筑师:3LHD
地点:克罗地亚
面积:11950平方米
年份:2021
  • 山河边城
    山河边城 沙发
    感谢楼主慷慨分享
    2022-04-24 16:50:24
140.17 万条内容 · 2232 人订阅
梁加腋构造与理解
解释了很多关于梁加腋的问题,对于加强梁加腋的认识与做法很有帮助。
