土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 大学医院校园设计
大学医院校园设计
发布于:2022-01-24 14:07:24 来自:建筑设计/公共建筑设计 [复制转发]
丹吉尔大学医院中心将令人联想到摩洛哥村庄乡土建筑的高品质多层医院结构无缝集成到丘陵景观中。丹吉尔大学医院中心与新的医学院和肿瘤学中心一起建立为真正的大学医院校园。它的建设加强了健康园区的总体结构,扩展了山丘周围各个地点实体的辐射几何形状。它将改善患者的治疗条件,并为学者创造一个出色的工作环境。
The University Hospital Center in Tangier seamlessly integrates a high-quality multibuilding hospital structure reminiscent of the vernacular architecture of Moroccan villages into the hilly landscape. The University Hospital Center in Tangier was set up as a genuine University Hospital campus alongside the new Faculty of Medicine and the Oncology Center. Its construction reinforces the general structure of the Health Campus, extending the radiant geometry of the various site’s entities around the hill. It will enhance the patient treatment conditions and will create an outstanding working environment for the academics.
大学医院设计可容纳 800 张床位,由三座建筑组成,位于一个共同的基础上。入口广场将患者引导至接待区以及与其他站点实体的连接处。一个大遮阳篷延伸了传统的 mashrabiya 画廊,可以俯瞰游客接待大厅,向城市开放。
该场地的限制强加了一个紧凑的建筑,同时还提供了大学医院运营所需的邻近和连接优势。底层整合了所有的后勤和接待活动,以及一个专门的紧急设施。第一层是操作区和技术支持中心。第二层包括大学医院的实验室和行政场所,顶层是三个普通住院中心,即普通内科、外科和母婴中心。
Designed for a capacity of 800 beds, the University Hospital consists of three buildings resting on a common base. The entrance square directs the patients to the reception areas and to the articulations with the other site entities. A large awning extends the traditional mashrabiya gallery that overlooks the visitor reception lobby, opening to the city. The site’s constraints impose a compact building, while also offering the advantage of proximities and connections required for the operation of the University Hospital. The base floor consolidates all the logistics and reception activities as well as a dedicated facility for emergencies. The first level accommodates the operating block and the technical support centre. The second level includes the University Hospital's laboratory and administrative premises, while the top floors are dedicated to three general hospitalisation centres, namely General Medicine, Surgery and Mother and Child.
丹吉尔大学医院中心项目非常重视环境维度:该建筑位于景观公园内,与地中海景观无缝融合。选定的标准结构布局(7.50 mx 7.50 m)提高了模块化、可扩展性和灵活性,并通过将承重墙限制在垂直通道的坚固核心上来预测未来可能的扩展需求。
底座被视为具有水平运行图案的石质基础,由大雨棚保护。这三个实体更加自主,在两个层面上主导着建设。他们的外立面由形成大屏幕墙的穿孔元素突出显示,并由房间的多色窗框点缀。根据一天中的时间,建筑物会产生各种对颜色和反射的感知。
The project of University Hospital Center Tangier attaches great importance to the environmental dimension: the building is located in a landscaped park, blending seamlessly into the Mediterranean landscape. The selected standard structural layout (7.50 m x 7.50 m) promotes modularity, scalability and flexibility and anticipates possible future expansion needs by limiting the load-bearing walls to the strong cores of the vertical access shafts. The base is treated as a stone foundation with horizontally running patterns, protected by a large canopy. The three entities, more autonomous, dominate the construction on two levels. Their external fa?ades are highlighted by perforated elements forming large screen walls, dotted by the multi-coloured window frames of the rooms. Depending on the time of day, the buildings produce a variety of perceptions of colours and reflections.
区位图
平面图
立面图
剖面图
建筑师:Hajji & Elouali Architecturestudio
地点:摩洛哥
面积:81000平方米
年份:2021
公共建筑设计
51.18 万条内容 · 448 人订阅
韦斯安德森镜头下,有多少甜品般的缤纷美学世界?
灵感星球 #视觉多巴胺 标志性的复古色调、强迫症一样的对称构图、精良的配乐,神经兮兮的冷幽默凑成了Wes Anderson(韦斯-安德森)特有的导演语言。作为Wes Anderson的影迷,都有一个共同的苦恼——本想截出一些好看的画面,到最后完全无法筛选,因每一帧都能美到当壁纸的程度。 Wes Anderson的电影,就像精神甜品一样,治愈又上头。今天我们不如来一起品尝几道不同风味的「韦式美食」吖~
