土木在线论坛 \ 建筑结构 \ 建筑加固 \ 【求助】农村房子有裂缝
【求助】农村房子有裂缝
发布于:2021-05-24 19:59:24 来自:建筑结构/建筑加固 [复制转发]
十来年前盖的房,还是预制板结构的没有用钢筋。后来又接了一层空心砖的。自从接完房子,房子就出现裂缝了,这几年来裂缝没见明显变化。这需要处理吗?IMG_20210523_115714.jpgIMG_20210523_115734.jpgIMG_20210523_115802.jpgIMG_20210523_115814.jpgIMG_20210523_180812.jpgIMG_20210523_181222.jpg
全部回复(5 )
  • cof1622595707756
    谢谢楼主分享好资料
    https://www.antpedia.com/?290372
    https://www.antpedia.com/?290371
    https://www.antpedia.com/?290370
    https://www.antpedia.com/?290368
    https://www.antpedia.com/?290347
    https://www.antpedia.com/?290351
    https://www.antpedia.com/?290380
    https://www.antpedia.com/?290382
    https://www.antpedia.com/?290383
    https://www.antpedia.com/?290386
    https://www.antpedia.com/?290389
    https://www.antpedia.com/?290390
    https://www.antpedia.com/?290392
    https://www.antpedia.com/?290393
    https://www.antpedia.com/?290394
    https://www.antpedia.com/?290395
    https://www.antpedia.com/?290396
    https://www.antpedia.com/?290397
    https://www.antpedia.com/?290398
    https://www.antpedia.com/?290438
    https://www.antpedia.com/?290439
    https://www.antpedia.com/?290441
    https://www.antpedia.com/?290442
    https://www.antpedia.com/?290443
    https://www.antpedia.com/?290445
    https://www.antpedia.com/?290446
    https://www.antpedia.com/?290447
    https://www.antpedia.com/?290448
    https://www.antpedia.com/?290449
    https://www.antpedia.com/?290450
    https://www.antpedia.com/?290451
    https://www.antpedia.com/?290452
    https://www.antpedia.com/?290453
    https://www.antpedia.com/?290454
    https://www.antpedia.com/?290455
    https://www.antpedia.com/?290456
    https://www.antpedia.com/?290457
    https://www.antpedia.com/?290458
    https://www.antpedia.com/?290460
    https://www.antpedia.com/?290461
    https://www.antpedia.com/?290462
    https://www.antpedia.com/?290463
    https://www.antpedia.com/?290464
    https://www.antpedia.com/?290465
    https://www.antpedia.com/?290467
    https://www.antpedia.com/?290468
    https://www.antpedia.com/?290469
    https://www.antpedia.com/?290470
    https://www.antpedia.com/?290473
    https://www.antpedia.com/?290474
    https://www.antpedia.com/?290475
    https://www.antpedia.com/?290476
    2021-06-02 09:03:02
  • wx_1621934101943
    看你描述,,这个房子盖的时候就根本没有按要求来盖,用的材料均未考虑抗震,后来又用空心砖加盖,说明盖房子的人完全不懂。那么大胆推测,地基没有处理,也没考虑温度的影响。推测为地基不均匀沉降,加上房屋整体性太差,所以变形过大形成裂缝。严格来说已经是危房。如果当地没有什么地震,比如说江西南部地区,那么居住问题不大,但是以后注意不要堆放过重的物品。
    像这种不说地区的。真是无法判断,西北地区还要考虑湿陷性,做好防排水处理。西南地区要考虑红土的膨胀性。东北藏区要考虑冻土的收缩性,湖泊海边地区要考虑盐碱土的变形。
    以后说问题,,最好说一下地区,降水对房子的影响什么的。就这样说。太多因素会造成这个结果。
    最好加上室内外地面的照片。外部环境。
    2021-05-25 17:30:25
建筑加固
1.66 万条内容 · 390 人订阅
建筑加固介绍建筑结构体系加固和构件加固
  建筑加固是利用碳纤维、粘钢、植筋等技术对建筑物进行加固的一种方法。建筑加固行业是随着建筑业的发展而发展起来的,其基础是庞大的既有建筑存量。对于建筑结构加固工程,可分为建筑结构体系加固和构件加固。系统加固是针对现行抗震鉴定标准中建筑结构整体抗震性能不足而提出的,构件加固是针对局部构件承载力不足而提出的。 方案设计应综合分析检验鉴定结果,根据具体情况和条件选择加固方案,以提高建筑物的整体性,改善构件、整体加固、截面加固的应力状态。或者对建筑物进行构件加固。重庆建筑加固对于配筋构件的布局,无论是否新增构件,都应减少甚至消除整体不利因素,以防止结构刚度或强度因局部加固而突然变化。
