杭州化纤厂旧址改造项目位于杭州市拱墅区蓝孔雀板块,包含杭实工发铭座办公园区和城市公园两部分, 其规划、建筑、景观、室内及软装设计由零壹城市一体化完成。
位于京杭大运河最南端的拱墅区是杭州传统工业区,聚集着杭钢、杭锅、蓝孔雀化纤厂等工业企业。蓝孔雀化纤厂是当时全国最大化纤企业之一,产品远销欧亚12个国家和地区。
Gongshu district, located at the southernmost of Beijing-Hangzhou Grand Canal, is a traditional industrial zone of Hangzhou, with industrial enterprises such as Hangzhou steel factory, Hangzhou pot, Blue Peacock chemical fabric factory, etc. Blue Peacock Chemical Fibre Factory was one of the largest fiber enterprises in China at that time. Its products were exported to twelve countries and regions in Eurasia.
In the 1990s, Gongshu District transitioned from industrial to urban life function. High-energy and high-emission enterprises in the region had been shut down and transferred one after another, and the original site of the Blue Peacock Chemical Fiber Factory had gradually been abandoned. Until 2018, Hangzhou Industrial Development Group joined hands with LYCS Architecture to launch the renovation project, which ushered in an opportunity to resurreate the old factory.
Repair the Old as the Old
There were five legacy buildings on the site, including four factories and one factory dormitory, which were built between the 1970s and 1990s. The building structure was mainly concrete frame structure and brick-mixed structure. The external facade was seriously eroded, and most of the doors and windows had been seriously damaged. people can still clearly feel the industrial atmosphere of the land through the mottled walls, rusty window frames and landmark roofs.
遗留建筑经专业机构评估,地基基础大部分符合现行国家标准的可靠性要求,予以保留;承重结构略低于现行国家标准的可靠性要求,但经过加固修缮即可符合要求;围护结构大多受潮严重,已无法满足保温、隔热、防水等基本要求,需拆除并重建。
围护结构中,拱形屋顶、老砖以及“抓革命,促生产”字样等要素极具时代标志性,在施工之初,这些时代记忆被小心翼翼的从建筑上完整的剥离、保留并做专业处理。
In the enclosure structure, arched roofs, old bricks and walls with the words "catching revolution and promoting production" were very landmark in the era. At the beginning of construction, these reserved elements were carefully peeled, retained and professionally processed from the building.
设计在立面上采用大面积的落地窗来满足办公空间对于光线品质的要求。竖向的窗框搭配简约的线条,古铜色的铝板与“修旧如旧”的墙体形成鲜明的对比,在工业遗存的原始粗犷中,点缀了现代办公建筑的精致感。
设计师在三栋旧厂房之间置入连廊以增强各功能空间的连贯性,满足现代办公的空间要求,给老厂房注入新的活力。连廊的材质与窗框一致,采用深灰色铝板来协调建筑的整体色调。
△连廊空间 | Corridor
Repair the Old as the New
新园区即将以全新的角色融入城市,业主和设计师都希望它除了带给人们工业时代的记忆之外,还有更多新生元素被置入其中,使其更好的满足现代化的办公需求,融入城市。
“小白楼”前身为化纤厂的员工宿舍,作为场地与城市的连接载体,“整旧如新”的设计策略使城市界面的连续性得以实现。其设计在保留原始框架结构的基础上,对立面进行改造。
The "Little White Building" used to be the employee dormitory of the chemical fiber factory. As the carrier of the connection between the site and the city, the design strategy of “repair the old as the new” to realize the continuity of the city interface. The design of the facade was modified on the basis of retaining the original frame structure.
△“小白楼”改造前后对比图
Comparison before and after the Renovation
The facade design of the "Small White Building" respected the number of column mesh modulus of the original structure. Through the staggered window opening design, it made the building innervation and visually weakens the heavy sense caused by the original building scale. The hidden design of the open fan makd the lines of the facade simple and symmetrical, and the visual effects presented were cleaner. While meeting the lighting and ventilation needs of office space, it also improved the overall texture of the building.
△“小白楼”北立面 | North facade of “Little White Building”
04
室内设计与建筑设计同步展开,延续建筑“修旧如旧,整旧如新”的设计理念。
设计采用一种“box in box”的方法:在原建筑框架结构(大box)内置入独立的各功能空间(小box),将现代化的办公空间置入老厂房。
△视线贯穿的会议室与接待区
Conference Room and Reception Area with Coherent Vision
开敞办公区作为box之一,其混凝土结构完全裸露,和保留的老红砖形成独特的界面韵律。与之相邻的另一个空间则采用木饰面、仿铜不锈钢等现代材料组合而成。通过新旧材料的强烈对比来自然划分办公和休闲空间,营造同一空间内的跨时空体验。
△员工餐厅 | Restaurant
05
Rebirth of Blue Peacock
画龙需点睛,“抓革命,促生产”的标语复位,保存下来的厂房老砖回归,原厂房的拱形混凝土屋面板被重新装回屋顶,在耗时两年的设计施工之后 ,蓝孔雀工业遗存公园已正式重新投入使用。跨越50年时空,历史印迹和现代生活交织在一起。以崭新的姿态回馈社区,融入城市。
设计公司: 零壹城市建筑事务所(建筑设计、室内设计、景观设计、软装设计)
设计团队: 阮昊、陈文彬、唐慧萍、张磊、张秋艳、沈双双、劳哲东、马广宇、邓皓、辛歆 、王一如、何昱楼、范竞文、赵一凡、柯安然
Project name: Renovation of Hangzhou Old Chemical Fiber Factory
Client : Hangzhou Gongfa Cultural Creativity Co., Ltd
Project Period: 2018-2020
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
震撼!全钢结构!全球首例最高非对称三塔连体“空中平台”,中国造!收录于话题 据说这是刚建成时,一位网友拍的 刚看到这个照片的时候,小编震惊了! 不比较不知道,和旁边的建筑相比,这简直是要冲出云端啊 看资料才知道,这是目前全世界 在建的、高度最高的、连体跨度最大 的非对称三塔连体结构— 南京金鹰世界 工程用钢总量达8万吨之多,相当于两座“鸟巢”的体量 连体结构的受力比一般单塔结构更复杂,这是业内公认的,
