恢复纯粹形式的价值。 北卡塔利纳斯的办公大楼是一个拥有土地矩阵的建筑,其容积率和平方米具有相当大潜力,并与形状相吻合。
三角形的地块最长的一面朝向河流,这个项目是在这种形式“挤出”的结果。三角形的建筑,其核心位于直角,具有出70米的办公楼层,面向拉普拉塔河。
Recovering the value of pure forms. It is a building that has a matrix of land whose volumetry and potentiality of square meters coincide with the shape: the triangular lot orients its longest side to the river. The project results from the extrusion of this form. A triangular-shaped building is generated, with the nucleus located towards the right angle, releasing office floors that obtain 70 meters of frontage facing the Rio de la Plata.
在两个尖锐的顶点上,通过弯曲的角和立面的连续性解决了冲突,这一决定类似于具有空气动力学边缘的飞机机翼。由于塔尖狭窄的形状,它变成了透明的,当阳光很低的时候,你可以从一边看到另一边。
In both acute vertices the meeting is resolved by curving the corners and giving continuity to the facade, this decision resembles the building to an airplane wing with aerodynamic edges. Due to its narrow shape at the tips, the tower becomes transparent, allowing you to see from side to side when the sunlight is low.
地下室遵循Catalinas Norte的准则,用石材解决,并融入植被和公共设备。通道顶棚是一块密斯式的工业剖面,当塔楼的表皮降到零时,它就会被切开。
The basement, which follows the guidelines of Catalinas Norte, is resolved in stone with incorporated vegetation and public equipment. The access canopy is a Miesian piece of industrial profiling that makes a cut when the skin of the tower is lowered to zero.
三倍高度的入口大厅为参观者提供了一个非凡的感受。空间性,四倍高的螺旋楼梯在建筑南侧的前部以双高向下盘旋,像雕塑一样。
The triple height entrance hall provides an extraordinary scale to the visitor. Spatiality that is finished off with a double height downwards in the southern prow of the building, with a helical staircase as a sculptural figure in the quadruple height.
这座塔楼建在Catalinas Norte的最后一块空地上,标志着这个始于20世纪70年代的城市作品的建设的结束。
地面平面图
1层平面图
4层平面图
标准层平面图
立面图
A-A剖面图
B-B剖面图
建筑师:胡安-曼努埃尔-马塞达&MSGSSS(Juan Manuel Maseda,MSGSSS)
地点:阿根廷
面积:55000 m2
年份:2020
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
