土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 一座高架桥穿过——规划展览馆设计
一座高架桥穿过——规划展览馆设计
发布于:2020-12-07 11:49:07 来自:建筑设计/公共建筑设计 [复制转发]
ZXD建筑事务所公布了在中国的一个展览厅的设计,它将记录一个新城镇的出现。建筑的官方名称是“凯州新城规划展览馆”,建筑的中心是一个巨大的空间,它是周围环境的“窗口”。
一座高架桥穿过这个空间,连接场地一侧的小山和另一侧的荷塘。在桥与结构相遇的地方,一个室外公共空间被创建在区域的中心。
ZXD architects has unveiled the design of an exhibition hall in china that will document the emergence of a new town. officially titled ‘the kaizhou new town planning exhibition hall’, the building is defined by the large void at its center, which serves as a ‘window’ to its surroundings. an elevated bridge traverses this void, connecting the hill on one side of the site to the lotus pond on the other. where the bridge encounters the structure, an outdoor public space is created at the heart of the scheme.
该展厅已经在建设中,将位于 凯 州 ,靠近中国四川省德阳市。ZXD建筑事务所解释说:“展馆位于新城主要开发区的位置意味着它不仅是新城重要的公共空间,也是新城向外界展示自身最直接的窗口。”
already under construction, the exhibition hall will be located in kaizhou in close proximity to the city of deyang in china’s sichuan province. ‘location within the leading development zone of the new town means that the exhibition hall is not only an important public space of the new town, but also the most direct window that the new town shows itself to the outside,’ explains ZXD architects.
展馆由中央空间两侧的两个体量组成,每个体量都有自己的入口、出口和垂直交通路线。一层的入口大厅连接南北体量,也作为主要接待大厅。
项目的堆叠体量被抵消,以创造露台和通向公共屋顶的室外流通路线。从这里,游客可以见证新城的发展,展览馆是新城发展的重要组成部分。
the exhibition hall comprises two volumes either side of the central void, each with their own entrances, exits, and vertical circulation routes. the entrance hall on the first floor connects the south and north volumes, and also serves as the main reception lobby. the project’s stacked volumes are offset to create terraces and outdoor circulation routes that lead to the public rooftop. from here, visitors can witness the growth of the new town with the exhibition hall forming an integral part of the development.
区位图
位置分析图
平面图
立面图
建筑师:BIAD-ZXD建筑师事务所
地点:四川省德阳市凯州新城
面积:7819.93平方米
年份:2020
公共建筑设计
51.18 万条内容 · 448 人订阅
商业建筑的创新探索与实践
近郊、目的性商业模式的创新探索与实践 天津华北城
