土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 阜阳市规划展示馆---形态简洁,功能完善的规划展示馆设计策略
发布于:2020-07-13 17:31:13 来自:建筑设计/公共建筑设计 [复制转发]
阜阳市规划展示馆
东南大学建筑设计研究院
项目背景
阜阳市规划展示馆(包括阜阳市档案馆、城建档案馆、国土局档案馆、房产局档案馆)位于阜阳市城南新区,总占地面积为5.21公顷,其中,用于场馆建设的为2.98公顷,公共绿地2.23公顷。
Fuyang Planning Exhibition Hall (including municipal archives, urban construction archives, land archives and real estate archives) is located in the center of Fuyang Southern New Area, with a total land area of 5.21 hectares (including 2.98 hectares for building construction and 2.23 hectares for public green space).
设计策略
加减:该项目涉及两种功能类型:规划成果的展陈教育和档案资料储藏查阅。
城市规划展示馆,城市档案馆,城建档案馆,国土局档案馆、房产局档案馆是五个独立运行的功能主体,是典型的展陈,服务和办公综合体建筑。
作为宏观形体组织控制策略,既保证了各功能主体的独立性,又确保了形态的简洁与完整性。
Addition and Subtraction:The project involves two functional types: exhibition and education of planning achievements, and storage and reference of archives. The city planning exhibition hall, city archives, urban construction archives, land archives and real estate archives are five independent functional subjects, which are typical exhibition, service and office complex buildings. As a volume control strategy, the combined operation of addition and subtraction ensures the independence of each functional subject and at the same time, keeps the simplicity and integrity of the form.
模块化设计:项目总高度为23m,其中档案服务区地上5层,标准层层高为4600mm;规划展示区地上4层,层高分别为4600mm和6100mm。这两个区域分别在2层和4层相连。平面选择了8700mm x 8700mm作为标准柱网,并在立面上投射出了1175mm和1000mm两种模块,帮助团队根据内部功能灵活地确定合适的窗地比。
Modular Design: The total height of the project is 23m, including 5 floors above the ground in the archive service area with 4600mm height, and 4 floors above the ground in the planning exhibition area with two heights of 4600mm and 6100mm. The two zones are connected on the 2nd and 4th floor respectively. 8700mm by 8700mm is selected as the standard column grid for the plan, and 1175mm and 1000mm are projected on the facade as modules, which helps the team to flexibly decide the appropriate ratio of windows according to the internal function.
开放性:得益于一系列公共空间,该项目吸引了城市各个方向的人流,表现出了最大的包容性和多维度的开放性。该设计通过提升公共空间的基层,实现了不同功能区出入口的立体布局,并通过大台阶营造了丰富的叙事感和庄重的仪式感。
Openness: Benefit from a series of public space, the project attracts people from all directions of the city, which shows the greatest inclusiveness and multi-dimensional openness. The design realizes the three-dimensional layout of the entrances and exits for different functional zones by raising the base level of the courtyard, and creates a rich sense of narration and a solemn sense of ceremony by the great steps.
绿色技术:建筑的布局借鉴了中国传统建筑的“合院式”布局理念,该项目非常重视调控局部小气候以及对自然通风和采光的利用。“被动”绿色建筑设计理念在当代公共建筑设计中的运用,充分体现在对体量,层高,立面窗地比的控制,以及三角形垂直金属遮阳系统。
Green Technology: The layout of the building draws on the courtyard concept from Chinese traditional style, and the project attaches great importance to the adjustment of local microclimate and the utilization of natural ventilation and lighting. The application of "passive" green building design concept in contemporary public building design is fully expressed by the control of volume, floor height, and the ratio of windows, as well as the triangular vertical metal sunshade system.
项目区位示意图
总平面图
一层平面图
二层平面图
三层平面图
四层平面图
五层平面图
立面图
剖面图
“减法”示意图
“加法”示意图
公共空间示意图
错层衔接示意图
模数控制示意图
采光通风分析
通风分析
建筑师:东南大学建筑设计研究院
地点:安徽 阜阳
主创建筑师:夏兵
设计团队: 夏兵、段进、袁玮、薛丰丰、陈澎、张麒
面积:51236平方米
年份:2017
摄影:侯博文
  • lijiawei411
    lijiawei411 沙发
    2020-07-26 15:41:26
公共建筑设计
51.18 万条内容 · 448 人订阅
标杆地产商业、办公、酒店、超高层、住宅机电系统管控技术
本文为转载文章:来自公众号:地产人小助手 国家针对地产行业持续调控,限购、限售、限价、限贷、限商等政策不断收紧,更多的传统住宅地产开发商转型为“商住并举”的综合型地产开发运营商,开发业态逐渐从住宅拓展至商业、办公、酒店、综合体、超高层、游乐、文化旅游业态等。机电系统也随着建筑业态的丰富,显得越来越复杂、重要,而且机电系统新技术、新工艺层出不穷,机电系统占建安工程费的比重也越来越高。在竞争更加激烈的地产行业“白银时代”,需要甲方机电管理人员更专业、更全面、更综合、更有全局观念。
