土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ CAD工具箱合集之七—【EF_Tools工具箱】
发布于:2010-10-13 16:23:13 来自:建筑设计/CAD下载及教程 [复制转发]
EF_CMDManage.vlx EF_CMDManage.ini -命令管理器,可将自定义命令增加到菜单中,并增加屏幕菜单,该 管理器可单独运行
EF_Tools 工具箱(必须和上面命令行管理器一起使用)
EF_Loader.lsp:EF_Tools工具箱启动文件
EF_Command.lsp:定义EF_Tools中各种命令行命令名
EF_Tools.ini:EF_Tools 工具箱配置文件
EF_Tools.VLX:EF_Tools 工具箱主程序
Initial.LSP:初始化一些变量
用法: 1.
将 EF_Tools 目录 增加到AutoCad搜寻目录
2.运行EF_Loader.lsp
功能简介及 命令如下
EF工具箱 = (menucmd "S=EF_Tools.Screen")
AutoCAD = (menucmd "S=Acad.Screen")
清空菜单 = C:EF_ClearScreenMenu
视图变换 = C:EF_ObjectPlan
;仅用于图纸空间
视口锁定 = C:EF_VportsLock
视口解锁 = C:EF_VportsUnLock
选层显示 = C:EF_LayerON
选层隐藏 = C:EF_LayerOFF
选层锁定 = C:EF_LayerLock
选层冻结 = C:EF_LayerFreeze
置当前层 = C:EF_ItemToClayer
设当前层 = C:ai_molc
按色分层 = C:EF_LayerCutByColor
线性标注 = C:EF_DimLinear
对齐标注 = C:EF_DimAligned
弧长标注 = C:EF_DimArc
标注合并 = C:EF_DimJoin
标注断开 = C:EF_DimBreak
标注避让 = C:EF_DimTextAutoMove
转角→对齐 = C:EF_DIM-Linear->Aligned
对齐→转角 = C:EF_DIM-Aligned->Linear
位置取齐 = C:EF_DimPosAlign
基点取齐 = C:EF_DimBaseAlign
沿线输入 = C:EF_TEXTByLine
文本对齐 = C:EF_TEXTAlign
万能编辑 = C:EF_TextEdit
转多行文本 = C:EF_TextToMText
文字加框 = C:EF_TextBox
剖面符号 = C:EF_Profiles
图名标题 = C:EF_Title
单剖断线 = C:EF_Post-Break1
双剖断线 = C:EF_Post-Break2
绘制标高 = C:EF_Elevation
引线标注 = C:EF_LeadLine
钢筋设置 = C:EF_ReinConfig
线变钢筋 = C:EF_ToRein
绘制板筋 = C:EF_ReinDraw
手工钢筋 = C:EF_ReinAny
绘点钢筋 = C:EF_DrawReinPoint
单段多点 = C:EF_ReinPointAtPLine
钢筋加钩 = C:EF_ReinAddHook
弯钩删除 = C:EF_ReinDelHook
钢筋反向 = C:EF_ReinSelfMirror
绘制轴线 = C:EF_AXIS
双线节点 = C:EF_Object_Trim#NodeCon
双线修剪 = C:EF_Object_Trim#
双线修剪2 = C:EF_Object_Trim#ByMaxDist
多义线闭合 = C:EF_Object_PLClose
块色随层 = C:EF_BlockByLayer
区间裁剪 = C:EF_TrimByCurve
区间编号 = C:EF_Object_CloseAreaNum
制图比例 = C:EF_Config_Scale
常用捕捉 = C:EF_OSNAP_Normal z
轴归零 = C:EF_Z0
默认设置 = C:EF_Config_Reset
重新加载 = C:EF_ReLoad
EF_Tools = (startapp (ef-info-dwggetkey "PARAMETER" "EDITAPP") (findfile "EF_Tools.ini"))
命令管理 = (startapp (ef-info-dwggetkey "PARAMETER" "EDITAPP") (findfile "EF_CMDManage.ini"))
[ 本帖最后由 jindi1945 于 2011-3-10 14:08 编辑 ]
全部回复(44 )
  • hcqrytcl
    hcqrytcl 沙发
    CAD工具箱合集
    2013-09-26 16:51:26
  • guo985369
    guo985369 板凳
    楼主怎么不介绍一下啊
    2012-09-07 21:35:07
CAD下载及教程
52.07 万条内容 · 656 人订阅
CAD工具箱合集之六—【网蜂CAD工具箱标准版2.50(20110101更新版).】
网蜂CAD工具箱2.041(20100924).part1V2.0412010.09241、新添更改桩类型功能 命令:NBTC_Stake_SetType2、多桩变号添加指定范围功能3、桩工具中查删相关添加进度指示功能V2.0402010.08.271、新添桩位批量变号功能2、修复承台绘制及标注无法在R2002/2000中运行的BUG3、桩坐标生成文件自定义坐标系中支持自动计算比例
