土木在线论坛 \ 环保工程 \ 水处理 \ 污水升级改造技术
污水升级改造技术
发布于:2008-02-12 14:34:12 来自:环保工程/水处理 [复制转发]
我们现在有一项国外成熟的技术,可以快速提升现有活性污泥系统的能力(COD和氨氮)和稳定性, 例如可用于1B到1A的改造和工业废水处理改造。该技术安装和维护可以在不停车的情况下进行。有愿意合作,请电邮到wastewater@live.cn,留下公司名称和联系方式。
The Apex System, added to existing activated sludge systems, increases the effective Mixed Liquor Suspended Solids (MLSS) inventory of the system without increasing solids loading to the clarifier. This economical, easy-to-install system upgrades a wastewater treatment facility without increasing tankage. The Apex system requires no additional maintenance and installs with little or no disruption to plant operations.
Increased Capacity
The flexible, high-surface-area media is submerged in the activated sludge tanks to provide extensive surface area for biomass growth. The attached biomass population can increase the effective MLSS concentration by over 3000-4000 mg/l, increasing organic load capacity. This also reduces F/M ratios, improving process control and stability
Higher MLSS Without Higher Clarifier Solids Loading
Because a significant portion of the active biomass remains attached to the Apex rather than suspended in the mixed liquor, organic removal increases without overloading secondary clarifiers with higher solids loads. For activated sludge systems with clarifier solids loading problems, treatment performance can be maintained or even improved while reducing MLSS loading to the secondary clarifier.
Resistant to Organic and Hydraulic Shock Loads
An “Achilles Heel” of activated sludge technology is the potential for peak hydraulic surges to “wash out” the suspended biomass from the aeration basins. With Apex, a significant amount of biomass is fixed in place and is available to treat the incoming organic load that accompanies hydraulic surges
Enhanced Nitrification
The biomass living on the Apex media increases MCRT (Sludge Age), promoting nitrification. During cold weather and where lower compliance limits are imposed, the added biomass improves the performance of nitrifying plants, or even allows non-nitrifying plants to nitrify.
Active Media Surface
Apex media has a tensile strength in excess of 1000 lbs. per lineal foot, yet is flexible enough to move like “reeds in a stream.” This movement creates localized turbulence that constantly renews surface areas and promotes oxygen transfer.
The total surface area available for biomass attachment at startup is up to 800 sq. ft. per cubic foot of installed media module. However, dry surface area does not tell the whole story. From those 800 sq. ft. of attachment points, the biomass grows underwater in 3 dimensions, creating flexible “branches” of non-blinding active surface area that can be measured in pounds per cubic foot, while still allowing for free flow of oxygenated wastewater through the media.
Economical
By improving wastewater treatment without adding aeration tankage or clarifiers, the Apex System is a low-cost solution to upgrading activated sludge plants.
Easy to Install
The entire Apex system can be installed without dewatering the aeration basin or modifying the aeration diffusers. The custom-sized/constructed Apex modules are lowered into the aeration basin with a crane and supported by the tank walls or on legs above the tank floor.
Durable and Long-Lasting
Apex is designed for durability and long life under the harsh conditions of an activated sludge aeration tank. The Apex media uses high-strength polyester. Even if a strand is cut or broken, the fabric will not fray or unravel.
全部回复(3 )
  • yikang59
    yikang59 沙发
    先把资料下下来看看,多谢分享了哈!
    2008-05-19 15:01:19
  • jinming2356
    jinming2356 板凳
    悬挂的填料吗?
    2008-05-17 19:55:17
水处理
43.47 万条内容 · 1517 人订阅
这样处理高浊度,高硬度的饮用水,可行不?多谢
饮用水处理,原水数据是(单位基本都是mg/L)pH 7.1碱度(CaCO3) 220硬度(CaCO3) 300Ca 硬度(CaCO3) 250温度 15浊度 42 NTU总铁 0.15总锰 0.03总有机物 4.8 消毒副产物前导物 2.9 浊度要处理到1NTU。我想的流程就是传统的方法:隔栅,pH控制和加氧化消毒剂,絮凝(加絮凝剂,除硬度),沉淀池(加CO2),沙滤,消毒,出水
