土木在线论坛 \ 建筑结构 \ MIDAS \ 请教Midas Civil弯梁的建模问题
发布于:2018-11-27 17:16:27 来自:建筑结构/MIDAS [复制转发]
我建了一个弯梁的模型,两端节点采用双支座模拟,从节点都定义了局部坐标。运行之后,信息窗口中显示了以下信息:
MULTI-FRONTAL SOLVERAVAILABLE MEMORY =    1.4 GBYTES
ENTRY PHASE FOR RENUMBERING
ENTRY NUMBERING_EQN
ENTRY FORM_STIFF_MASS_LOAD
THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED.
ELEMENT NO. :     26  OF      26
ENTRY SOLUTION PHASE
ENTRY LOAD_BLOCK
TOTAL NUMBER OF VALID DOFS IN MODEL :     162
ENTRY ASSM_STIFF_LOAD ( FORM GLOBAL EQUILIBRIUM EQUATIONS IN BLOCKS )
ENTRY STATIC ANALYSIS
MULTI-FRONTAL SOLUTION HAS BEEN PERFORMED 90 % .
WARNING : NODE NO.     14  RZ  DOF MAY BE SINGULAR.WARNING : EQUATION NO.        84
WARNING : NODE NO.     14  DX  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.        79
WARNING : NODE NO.     14  DY  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.        80
WARNING : NODE NO.     14  RY  DOF MAY BE SINGULAR.
MULTI-FRONTAL SOLUTION HAS BEEN COMPLETED.
DISPLACEMENT/FORCE/STRESS OUTPUT.WARNING : DISPLACEMENT DZ AT NODE NO.      1 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      1 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      1 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.      2 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      2 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      2 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.      3 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      3 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      3 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.      4 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      4 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      4 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.      5 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      5 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      5 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.      6 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      6 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      6 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.      7 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      7 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      7 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.      8 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      8 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      8 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.      9 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.      9 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.      9 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     10 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     10 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     10 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     11 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     11 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     11 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     12 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     12 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     12 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     13 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     13 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     13 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     14 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     14 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     14 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     15 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     15 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     15 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     16 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     16 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     16 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     17 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     17 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     17 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     18 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     18 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     18 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     19 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     19 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     19 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     20 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     20 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     20 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     21 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     21 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     21 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     22 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     22 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     22 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     23 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     23 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     23 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     24 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     24 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     24 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     25 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     25 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     25 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     26 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     26 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     26 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO.     27 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO.     27 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO.     27 IS ABNORMAL.
ELEM. :     26 OF      26
MIDAS
5.84 万条内容 · 317 人订阅
请教一下弯桥如何建模。
请教各位大神,钢结构弯桥是如何建模的?谢谢!
