材質的語彙界定空間的量體
對比量體錯層堆疊
沉穩與律動相互交融
線條貫穿延伸平衡空間重量
-場域界定
置入兩空間量體使開放場域自然而成,以材質線條與燈光分界空間量體,增添原本一分為三的空間場域,形成另一獨特區域。
-量體劃分
空間一分為二,一邊以單一素材建築手法延伸空間深度。另一邊以材質漸變方式減化量體的存在感;暗喻空間的界定,錯落的光跟影讓空間本質交錯流動。
-引光入室
光:主空間在規劃上運用基地條件,採用垂直動線;引光入室。
影:延續性空間,燈光透過材質錯層散佈在空間之中,反射的光跟影,營造空間趣味性。
-質
空間以石、木潤色
鍍鈦包覆量化空間
透過反射性材料,延續材料本身的質;因反射交疊,傳遞空間多變的生活面向
The vocabulary of textures is what defines
structures in a space.
Contrasting structures are stacked
together, blending steadfastness and a
vigorous rhythm, while lines pass through
the structures to balance the whole space
so that it doesn't feel too heavy.
- Defining sections
Two spacial structures are placed in to naturally create an open space. Lines of material and light serve to separate areas from each other, splitting the original area into three new sections and forming another unique section within itself.
- The dividing of structures
The space is split in two. One side employs a single material to give the structure depth and spaciousness, while the other side employs different materials that gradually blend into each other, so that the structures are less obvious and the line between spaces is less clear, to the point that it is nothing more than a metaphor. Lighting is scattered around the room, making the essence of the space seem flowing instead of static.
Letting light into the room
Light
The main space uses base conditions in its planning, and lets light into the room through a vertical flow.
Shadows
In a continuity of space, the light is scattered around the space through multi-level textures. The light and shadows, thus reflected, create a fun feeling throughout the whole space.
-Textures
The space is further decorated by stone and wooden textures, with titanium coated over quantized space. Through reflective materials, the textures of the material themselves are continued; and through reflections and split layers, the versatile space signifies the ever-changing quality of life.
家装设计
返回版块22.34 万条内容 · 392 人订阅
岩隐│核筑 Rock hidden│Build主要设计概念由送子鸟的到来开始 作為此一孕育生命医疗空间的主轴 安排林荫的穿梭层次 创造空间的场景故事 树影.岩石.足跡.巢窝化為空间的布局元素 一段乘载生命的旅程 作為人生初始阶段的开始 核 医疗空间的平面布局 安排一个扩散的核心动线 由中心向四周发散 简化单纯统一的服务动线 以核的概念一种孕育生命的方式 描述胚胎养份供给的想法 垂直动线的整合到隐私路径的安排 成功的解决医疗动线的问题
