土木在线论坛 \ 电气工程 \ 工业自动化 \ 结晶器液位控制
结晶器液位控制
发布于:2007-12-14 23:48:14 来自:电气工程/工业自动化 [复制转发]
目录
1技术参数 ______________________________________________________________ 3
2组成描述 ________________________________________________ 4
2.1简要描述 ____________________________________________________________________ 4
2.2控制系统 _____________________________________________________________________ 4
3马达_______________________________________________________________________ 4
4外围设备 __________________________________________________________ 4
5操作 ____________________________________________________________________ 5
5.1操作原理 ________________________________________________________________ 5
5.2操作员站 ___________________________________________________________________ 5
5.2.1 OS1铸流操作员站 _________________________________________________________________ 5
5.2.2 OS2紧急操作 ___________________________________________________________________ 6
5.2.3中包车1中包塞棒的LC141 __________________________________________________________ 6
5.2.3.1自动开始顺序和因数 ____________________________________________________________ 8
5.2.4中包车2中包塞棒的LC151 _________________________________________________________ 11
5.3人机界面HMI ___________________________________________________________ 12
5.3.1过程显示 __________________________________________________________________________ 12
5.3.2操作/状态窗口 __________________________________________________________________ 13
5.3.3报警/事件列表_________________________________________________________________________ 14
5.3.4趋势(历史的)_________________________________________________________________________ 15
6控制 _____________________________________________________________________ 16
6.1安全逻辑_______________________________________________________________________ 17
6.1.1事故关闭的硬接线 _________________________________________________________________ 17
6.2平行的控制信号(每一个中包车是相同的) _____________________________________ 18
6.2.1从铸流PLC到结晶器液位控制PLC ____________________________________________ 18
6.2.1.1拉矫驱动的总电流(模拟信号) _____________________________________________ 18
6.2.1.2实际的结晶器液位(模拟信号) ________________________________________________________ 18
6.2.2从结晶器液位控制PLC到铸流PLC ____________________________________________ 18
6.2.2.1拉矫驱动启动(数字信号) ____________________________________________________ 18
6.3总线-接口 _____________________________________________________________________ 19
6.3.1结晶器液位控制PLC和铸流PLC之间的Prfibus-DP接口(每一个中包车是相同的) 19
6.3.1.1总体定义 ___________________________________________________________________ 19
6.3.1.2数据传输 ________________________________________________________________________ 19
6.3.1.3发送数据从铸流PLC到结晶器液位控制PLC ______________________________________ 20
6.3.1.4 ____________________________________________________________________________________ 22
6.3.1.5发送数据从结晶器液位控制PLC到铸流PLC ______________________________________ 22
6.4报警定义: __________________________________________________________________ 27
6.5 二级接口 ___________________________________________________________________ 29
7块图 ____________________________________________________________ 30
8草图______________________________________________________________________ 32
1 TECHNICAL DATA 技术参数
*)从结晶器顶端/底端(结晶器的基本高度是900毫米)
值 单位
位置测量装置 mm
定位装置 设定值和阀的反馈
结晶器(机械参数)
结晶器长度 mm
结晶器定部宽度最小值 mm
结晶器定部宽度最小值 mm
结晶器厚度 mm
液压缸
液压缸行程 mm
液压缸速度 0.1 m/sec
液压缸在预热位置的速度 5 mm/sec
塞棒
塞棒特性 Kg/m*sec
结晶器液位控制值
实际的结晶器顶部范围(100%) 0/900*) mm
实际的结晶器底部范围(0%) 160/740*) mm
实际的结晶器液位-MAX MAX报警 25/875*) mm
实际的结晶器液位-MAX报警 30/870*) mm
实际的结
工业自动化
17.93 万条内容 · 389 人订阅
[求助}传送数据从S7到WINCC中
传送数据从S7到WINCC中,要传送的数据前面己经插上了小旗,但在其属性里面的运行控制和监视无法勾选,有人能解答一下吗?
