土木在线论坛 \ 广播专区 \ 广播专版 \ P-AirFilter G4纸框过滤器It is of low resistance, can take a large amount of ...
发布于:2017-04-12 17:53:12 来自:广播专区/广播专版 [复制转发]
P-Air
Filter G4纸框过滤器
air, has large capacity of dust accommodation, is of simple structure and is
easy for installation and cheap in price. It is non-toxic, odorless,
temperature withstanding and moisture withstanding and resistant to acid, alkaline
and organic solvents. The filter is simple in structure, reliable in sealing,
easy for filter materials and it is the Grade 1 filtration material for air
purification systems.
低阻力、大风量、高容尘、结构简单、安装更换方便、价格便宜。无毒、无味、耐温、耐湿、耐酸碱、耐有机溶剂等特点,该过滤器结构简单,密封性可靠,更换滤料方便,空气净化系统中的第一级过滤材料。
广播专版
1.6 万条内容 · 1 人订阅
Filter G4纸框过滤器
Filter G4纸框过滤器
