土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 点式建筑和条式建筑怎么区分?
点式建筑和条式建筑怎么区分?
发布于:2007-11-08 15:02:08 来自:建筑设计/公共建筑设计 [复制转发]
节能设计中提到:条式建筑体形系数不应超过0.35,点式建筑的体形系数不应超过0,.40(夏热冬冷地区)
点式建筑和条式建筑怎么区分?
公共建筑设计
51.18 万条内容 · 448 人订阅
百叶的防风雨问题
至于防雨通风的原理,主要是如下所述: 1 Air and rain enters between the louvre blades.2 Water is transferred to the second louvre where it is collected.3 Water is transferred along the blades and into the hollow vertical mullion thus preventing re-entrainment, draining the collected water onto the cill
