土木在线论坛 \ 暖通空调 \ 暖通资料库 \ 負荷估算軟件
負荷估算軟件
发布于:2007-11-07 18:50:07 来自:暖通空调/暖通资料库 [复制转发]
Green Toolbox 5.0 - HVAC Energy Improvement Software
The Green Toolbox 5.0 software program contains 25 simple HVAC-and-related "green" utilities for sizing duct work, sizing piping, sizing HVAC equipment, calculating cooling and heating loads for commercial and residential buildings, calculating psychrometric properties of air, performing U-Value calculations, and much more, all in the name of saving energy and the environment.
The following utilities are included:
A Metric-English converter
Single-state psychrometric calculations
Mixed-air psychrometric calculations
Duct sizing calculations
ASHRAE duct fitting pressure loss calculations
General pipe sizing
Hot/chilled water pipe sizing
Steam pipe sizing
Low pressure gas pipe sizing
High pressure gas pipe sizing
Refrigerant pipe sizing
Fan cost analysis
Fan curve analysis
Pump curve analysis
Rule-of-thumb commercial HVAC load calculations
Simple residential/light commercial HVAC load calculations
Swimming pool heating calculations
U-value calculations
gbXML parser
Wire sizing utility
Glass moisture condensation
Life-Cycle cost analysis
A super calculator for complex equations.
Manage HVAC equipment lists
Manage climatic weather data
全部回复(6 )
  • biosfix
    biosfix 沙发
    这个elite chvac 我常用,网上有很多破解,实际上是注册文件生成程序,能把演示版变正式版。
    软件的演示版在开发商网站可以下载。
    2009-10-05 22:36:05
  • berniewong
    berniewong 板凳
    好東西,能上傳大家分享嗎,大大!謝謝
    2008-05-17 19:45:17
暖通资料库
25.5 万条内容 · 720 人订阅
小弟是刚接触制冷的新人,希望各位前辈推荐几本书。
小弟刚加入论坛的新人也是刚接触制冷,跪求 拜求加急切希望看高田秋一写的两本书《离心式制冷机》《吸收式制冷机》两本书,但在论坛上的《离心式制冷机》只能下part1,以后就不能下了,希望各位大侠 前辈帮帮小弟,小弟在此万分感谢!adq123@yahoo.com
