土木在线论坛 \ 建筑结构 \ MIDAS \ 各位大神,求救呀
各位大神,求救呀
发布于:2016-05-06 16:02:06 来自:建筑结构/MIDAS [复制转发]
CEMENT DX AT NODE NO. 123 IS ABNORMAL.
CONSTRUCTION STAGE RESULTS SAVED TO FN.CA6 FILE
CONSTRUCTION STEP NO. : 21 / 58 STAGE NO : 11 STEP NO : 1
ENTRY PHASE FOR RENUMBERING
ENTRY NUMBERING_EQN
ENTRY FORM_STIFF_MASS_LOAD
THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED.
ELEMENT NO. : 95 OF 152
ENTRY SOLUTION PHASE
ENTRY LOAD_BLOCK
TOTAL NUMBER OF VALID DOFS IN MODEL : 588
ENTRY ASSM_STIFF_LOAD ( FORM GLOBAL EQUILIBRIUM EQUATIONS IN BLOCKS )
ENTRY STATIC ANALYSIS FOR NONLINEAR.
ITERATION NO. : 1 DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
WARNING : NODE NO. 66 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 282
WARNING : NODE NO. 66 RY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 281
WARNING : NODE NO. 66 RX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 280
WARNING : NODE NO. 66 DZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 279
WARNING : NODE NO. 66 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 278
WARNING : NODE NO. 66 DX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 277
WARNING : DISPLACEMENT DX AT NODE NO. 18 IS ABNORMAL.
WARNING : DISPLACEMENT DX AT NODE NO. 64 IS ABNORMAL.
WARNING : DISPLACEMENT DY AT NODE NO. 64 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 64 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO. 64 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO. 64 IS ABNORMAL.
WARNING : DISPLACEMENT RZ AT NODE NO. 64 IS ABNORMAL.
WARNING : DISPLACEMENT DX AT NODE NO. 65 IS ABNORMAL.
WARNING : DISPLACEMENT DY AT NODE NO. 65 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 65 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO. 65 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO. 65 IS ABNORMAL.
WARNING : DISPLACEMENT RZ AT NODE NO. 65 IS ABNORMAL.
WARNING : DISPLACEMENT DX AT NODE NO. 66 IS ABNORMAL.
WARNING : DISPLACEMENT DY AT NODE NO. 66 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 66 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO. 66 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO. 66 IS ABNORMAL.
WARNING : DISPLACEMENT RZ AT NODE NO. 66 IS ABNORMAL.
WARNING : DISPLACEMENT DX AT NODE NO. 67 IS ABNORMAL.
WARNING : DISPLACEMENT DY AT NODE NO. 67 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 67 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO. 67 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO. 67 IS ABNORMAL.
WARNING : DISPLACEMENT RZ AT NODE NO. 67 IS ABNORMAL.
WARNING : DISPLACEMENT DX AT NODE NO. 68 IS ABNORMAL.
WARNING : DISPLACEMENT DY AT NODE NO. 68 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 68 IS ABNORMAL.
WARNING : DISPLACEMENT RX AT NODE NO. 68 IS ABNORMAL.
WARNING : DISPLACEMENT RY AT NODE NO. 68 IS ABNORMAL.
WARNING : DISPLACEMENT RZ AT NODE NO. 68 IS ABNORMAL.
ERROR NORM IS NaN or INFINITE
THE PROGRAM IS ABORTED
ERRORS ENCOUNTERED. MIDAS JOB TERMINATED. REFER TO .OUT FILE
-------------------------------------------------------------这怎么解决啊,重做一遍还是这样
  • 愚鱼遇雨
    愚鱼遇雨 沙发
    我自己的原因是在CAD中按mm建模,导入midas的时候,程序默认的单位是m,结构尺寸相差1000倍。将CAD重新导入midas前,将单位设置为mm,警告不再出现。
    2016-12-16 21:41:16
MIDAS
5.84 万条内容 · 317 人订阅
midas运行后出错大神帮忙看看哪错了
MULTI-FRONTAL SOLVERAVAILABLE MEMORY = 1.4 GBYTESENTRY PHASE FOR RENUMBERINGENTRY NUMBERING_EQN ENTRY FORM_STIFF_MASS_LOAD THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED. ELEMENT NO. : 237 OF 237
