土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 适合新手用的天正快捷键
适合新手用的天正快捷键
发布于:2016-04-11 17:50:11 来自:建筑设计/居住建筑设计 [复制转发]
本人在工作中,总结出的最好用的天正快捷键,直接复制粘贴到,cad程序自定义里面的txt替换保存重启cad天正即可
3A, *3DARRAY
3DO, *3DORBIT
3F, *3DFACE
3P, *3DPOLY
A, *ARC
AC, *BACTION
ADC, *ADCENTER
AA, *AREA
AL, *ALIGN
AP, *APPLOAD
AR, *ARRAY
-AR, *-ARRAY
ATT, *ATTDEF
-ATT, *-ATTDEF
ATE, *ATTEDIT
-ATE, *-ATTEDIT
ATTE, *-ATTEDIT
B, *BLOCK
-B, *-BLOCK
BC, *BCLOSE
BE, *BEDIT
BH, *HATCH
BO, *BOUNDARY
-BO, *-BOUNDARY
BR, *BREAK
BS, *BSAVE
CI, *CIRCLE
CH, *PROPERTIES
-CH, *CHANGE
CHA, *CHAMFER
CHK, *CHECKSTANDARDS
CLI, *COMMANDLINE
COL, *COLOR
COLOUR, *COLOR
C, *COPY
CP, *COPY
CT, *CTABLESTYLE
DI, *DIMSTYLE
DAL, *DIMALIGNED
DAN, *DIMANGULAR
DAR, *DIMARC
JOG, *DIMJOGGED
DBA, *DIMBASELINE
DBC, *DBCONNECT
DC, *ADCENTER
DCE, *DIMCENTER
DCENTER, *ADCENTER
DCO, *DIMCONTINUE
DDA, *DIMDISASSOCIATE
DDI, *DIMDIAMETER
DED, *DIMEDIT
D, *DIST
DIV, *DIVIDE
DJO, *DIMJOGGED
DLI, *DIMLINEAR
DO, *DONUT
DOR, *DIMORDINATE
DOV, *DIMOVERRIDE
DR, *DRAWORDER
DRA, *DIMRADIUS
DRE, *DIMREASSOCIATE
DRM, *DRAWINGRECOVERY
DS, *DSETTINGS
DST, *DIMSTYLE
DT, *TEXT
DV, *DVIEW
ER, *ERASE
ED, *DDEDIT
EL, *ELLIPSE
E, *EXTEND
EXIT, *QUIT
EX, *EXPORT
EXT, *EXTRUDE
F, *FILLET
FI, *FILTER
G, *GROUP
-G, *-GROUP
GD, *GRADIENT
GR, *DDGRIPS
BH, *BHATCH
-H, *-HATCH
HE, *HATCHEDIT
HI, *HIDE
I, *INSERT
-I, *-INSERT
IAD, *IMAGEADJUST
IAT, *IMAGEATTACH
ICL, *IMAGECLIP
IM, *IMAGE
-IM, *-IMAGE
IMP, *IMPORT
IN, *INTERSECT
INF, *INTERFERE
IO, *INSERTOBJ
J, *JOIN
L, *LINE
LA, *LAYER
-LA, *-LAYER
LE, *QLEADER
LEN, *LENGTHEN
LI, *LIST
LINEWEIGHT, *LWEIGHT
LO, *-LAYOUT
LS, *LIST
LT, *LINETYPE
-LT, *-LINETYPE
LTYPE, *LINETYPE
-LTYPE, *-LINETYPE
LTS, *LTSCALE
LW, *LWEIGHT
V, *MOVE
MA, *MATCHPROP
ME, *MEASURE
MI, *MIRROR
ML, *MLINE
MO, *PROPERTIES
MS, *MSPACE
MSM, *MARKUP
MT, *MTEXT
MV, *MVIEW
O, *OFFSET
OP, *OPTIONS
ORBIT, *3DORBIT
OS, *OSNAP
-OS, *-OSNAP
P, *PAN
-P, *-PAN
PA, *PASTESPEC
PARAM, *BPARAMETER
PARTIALOPEN, *-PARTIALOPEN
PE, *PEDIT
PL, *PLINE
PO, *POINT
POL, *POLYGON
PR, *PROPERTIES
PRCLOSE, *PROPERTIESCLOSE
PROPS, *PROPERTIES
PRE, *PREVIEW
PRINT, *PLOT
PS, *PSPACE
PTW, *PUBLISHTOWEB
PU, *PURGE
-PU, *-PURGE
QC, *QUICKCALC
R, *REDRAW
RA, *REDRAWALL
RE, *REGEN
REA, *REGENALL
REC, *RECTANG
REG, *REGION
REN, *RENAME
-REN, *-RENAME
REV, *REVOLVE
RO, *ROTATE
RPR, *RPREF
RR, *RENDER
S, *STRETCH
SC, *SCALE
SCR, *SCRIPT
SE, *DSETTINGS
SEC, *SECTION
SET, *SETVAR
SHA, *SHADEMODE
SL, *SLICE
SN, *SNAP
SO, *SOLID
SP, *SPELL
SPL, *SPLINE
SPE, *SPLINEDIT
SSM, *SHEETSET
ST, *STYLE
STA, *STANDARDS
SU, *SUBTRACT
T, *MTEXT
-T, *-MTEXT
TA, *TABLET
TB, *TABLE
TH, *THICKNESS
TI, *TILEMODE
TO, *TOOLBAR
TOL, *TOLERANCE
TOR, *TORUS
TP, *TOOLPALETTES
TR, *TRIM
TS, *TABLESTYLE
UC, *UCSMAN
UN, *UNITS
-UN, *-UNITS
UNI, *UNION
VI, *VIEW
-V, *-VIEW
VP, *DDVPOINT
-VP, *VPOINT
VS, *BVSTATE
W, *WBLOCK
-W, *-WBLOCK
WE, *WEDGE
X, *EXPLODE
XA, *XATTACH
XB, *XBIND
-XB, *-XBIND
XC, *XCLIP
XL, *XLINE
XR, *XREF
-XR, *-XREF
Z, *ZOOM
AV, *DSVIEWER
CP, *COPY
DIMALI, *DIMALIGNED
DIMANG, *DIMANGULAR
DIMBASE, *DIMBASELINE
DIMCONT, *DIMCONTINUE
DIMDIA, *DIMDIAMETER
DIMED, *DIMEDIT
DIMTED, *DIMTEDIT
DIMLIN, *DIMLINEAR
DIMORD, *DIMORDINATE
DIMRAD, *DIMRADIUS
DIMSTY, *DIMSTYLE
DIMOVER, *DIMOVERRIDE
LEAD, *LEADER
TM, *TILEMODE
SAVEURL, *SAVE
OPENURL, *OPEN
INSERTURL, *INSERT
AAD, *DBCONNECT
AEX, *DBCONNECT
ALI, *DBCONNECT
ASQ, *DBCONNECT
ARO, *DBCONNECT
ASE, *DBCONNECT
DDATTDEF, *ATTDEF
DDATTEXT, *ATTEXT
DDCHPROP, *PROPERTIES
DDCOLOR, *COLOR
DDLMODES, *LAYER
DDLTYPE, *LINETYPE
DDMODIFY, *PROPERTIES
DDOSNAP, *OSNAP
DDUCS, *UCS
ACADBLOCKDIALOG, *BLOCK
ACADWBLOCKDIALOG, *WBLOCK
ADCENTER, *ADCENTER
BMAKE, *BLOCK
BMOD, *BLOCK
BPOLY, *BOUNDARY
CONTENT, *ADCENTER
DDATTE, *ATTEDIT
DDIM, *DIMSTYLE
DDINSERT, *INSERT
DDPLOTSTAMP, *PLOTSTAMP
DDRMODES, *DSETTINGS
DDSTYLE, *STYLE
DDUCS, *UCSMAN
DDUCSP, *UCSMAN
DDUNITS, *UNITS
DDVIEW, *VIEW
DIMHORIZONTAL, *DIMLINEAR
DIMROTATED, *DIMLINEAR
DIMVERTICAL, *DIMLINEAR
DOUGHNUT, *DONUT
DTEXT, *TEXT
DWFOUT, *PLOT
DXFIN, *OPEN
DXFOUT, *SAVEAS
PAINTER, *MATCHPROP
PREFERENCES, *OPTIONS
RECTANGLE, *RECTANG
SHADE, *SHADEMODE
VIEWPORTS, *VPORTS
;;轴网
HZZW, *T81_TAxisGrid
QSZW, *T81_TWall2Axis
ZWBZ, *T81_TAxisDim2p
DZBZ, *T81_TAxisDimp
CPZH, *T81_TReAxisNo
TBZH, *T81_TAddLabel
SCZH, *T81_TDelLabel
TJZX, *T81_TInsAxis
ZXCJ, *T81_TClipAxis
DPZH, *TRevAxno
ZGXX, *T81_TAxisDote
YZDH, *T81_TMutiLabel
ZHYX, *T81_TShowLabel
ZFZH, *T81_TChAxisNo
ZWHB, *T81_TMergeAxis
;;柱子
BZZ, *T81_TInsColu
JZ, *T81_TCornColu
PZZZ, *T81_TPolyColu
YXZ, *T81_TPolyColu
GGD, *T81_TChHeight
GZZ, *T81_TFortiColu
ZQQB, *T81_TAlignColu
TJB, *T81_TStatVolume
TJZB, *T81_TPrjVolume
;;墙体
HZQT, *T81_TWall
DFJQ, *T81_TDivWall
DXBQ, *T81_TSWall
ZXSQ, *T81_TSWall
DQJ, *T81_TFillet
DXJ, *T81_TChamfer
XQJ, *T81_TFixWall
BXDQ, *T81_TAlignWall
GQH, *T81_TWallTHick
GWQH, *T81_TExtThick
QDFK, *T81_TChWallTerm
QZBW, *T81_TAddInsulate
GWQG, *T81_TChEWallHeight
YXLM, *T81_TShapeWall
JXLM, *T81_TDelWallShape
QMUCS, *T81_TUcsWall
SBNW, *T81_TMarkWall
ZDNQ, *T81_TMarkIntWall
ZDWQ, *T81_TMarkExtWall
JLWQ, *T81_THLExtWall
QTZX, *T81_TAddPatch
PXSX, *T81_TWall2Curve
JXDQ, *T81_TAdjWallBase
JJPY, *T81_TOffset
QQWD, *T81_TWallAlignroof
QTFD, *T81_TPartwall
ZWMQ, *T81_TConvertCurtain
;;门窗
MC, *T81_TOpening
DXC, *T81_TBanWin
ZHMC, *T81_TGroupOpening
ZJC, *T81_TCornerWin
YXD, *T81_TPolyHole
MCT, *T81_TOpSlot
MCBH, *T81_TChWinLab
MCJC, *T81_TValidOp
MCB, *T81_TStatOp
MCZB, *T81_TPrjOp
MCYX, *T81_TOpTem
MKX, *T81_TDoorLine
BHFW, *T81_TResetLabPos
NWFZ, *T81_TMirWinIO
CLYS, *T81_TMapWinFrame
CLZK, *T81_TExpWinFrame
JZST, *T81_TOpeningSlot
MCTH, *T81_TReplaceOpening
MCRK, *T81_TWin2Lib
BHHZ, *T81_TLabelFix
BHSZ, *T81_TSetWinLab
MCGZ, *T81_TWDRegul
MCTQ, *T81_TFillOpening
全部回复(6 )
  • qq_1459476365697
    赞赞赞赞赞赞赞
    2016-04-20 23:35:20
  • zjjyl1984
    zjjyl1984 板凳
    赞赞赞赞赞赞赞
    2016-04-20 14:45:20
居住建筑设计
28.74 万条内容 · 423 人订阅
自建房设计的一些想法和现状
:)在刚毕业的时候,我就尝试在网上接自建房设计的设计。以前的业主都比较好,不会耍滑头,一般给了个大概想法,出个总体布置方案就会给钱。 :Q但是,现在很多人都是要你把成果都出了很多,才愿意给钱,甚至杳无音讯。 :(设计是个需要深思熟虑的工作,要考虑的因素很多,付出了劳动接受报酬应该是理所当然的吧。 :victory:大家都互相尊重并且有节操,放着质量不说,有人为你免费设计当然好,但是别因为吝啬几个钱而把自己一辈子住的房子随意摆弄。
