土木在线论坛 \ 建筑结构 \ MIDAS \ 不知道哪里出错了帮修改下
不知道哪里出错了帮修改下
发布于:2015-11-22 08:36:22 来自:建筑结构/MIDAS [复制转发]
不知到哪里出错了,求大神
  • co1448152173127
    MULTI-FRONTAL SOLVER
    AVAILABLE MEMORY = 1.4 GBYTES
    CONSTRUCTION STEP NO. : 1 / 38 STAGE NO : 1 STEP NO : 1
    ENTRY PHASE FOR RENUMBERING
    ENTRY NUMBERING_EQN
    ENTRY FORM_STIFF_MASS_LOAD
    THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED.
    ELEMENT NO. : 12 OF 20
    ENTRY SOLUTION PHASE
    ENTRY LOAD_BLOCK
    TOTAL NUMBER OF VALID DOFS IN MODEL : 69
    ENTRY ASSM_STIFF_LOAD ( FORM GLOBAL EQUILIBRIUM EQUATIONS IN BLOCKS )
    ENTRY STATIC ANALYSIS FOR NONLINEAR.
    ITERATION NO. : 1 DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
    ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.00000E+00 CONVERGENCE TOLERANCE .. : 0.10000E-01
    CONSTRUCTION STAGE RESULTS SAVED TO FN.CA6 FILE
    CONSTRUCTION STEP NO. : 2 / 38 STAGE NO : 1 STEP NO : 2
    ENTRY NUMBERING_EQN
    ENTRY LOAD_BLOCK
    ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
    ITERATION NO. : 3 DISPLACEMENT ERROR NORM .. : 0.00000E+00 CONVERGENCE TOLERANCE .. : 0.10000E-01
    CONSTRUCTION STEP NO. : 3 / 38 STAGE NO : 2 STEP NO : 1
    ENTRY NUMBERING_EQN
    ELEMENT NO. : 19 OF 20
    ENTRY LOAD_BLOCK
    TOTAL NUMBER OF VALID DOFS IN MODEL : 111
    CONSTRUCTION STEP NO. : 4 / 38 STAGE NO : 2 STEP NO : 2
    ENTRY NUMBERING_EQN
    ENTRY LOAD_BLOCK
    CONSTRUCTION STEP NO. : 5 / 38 STAGE NO : 3 STEP NO : 1
    ENTRY NUMBERING_EQN
    ENTRY LOAD_BLOCK
    CONSTRUCTION STEP NO. : 6 / 38 STAGE NO : 3 STEP NO : 2
    ENTRY NUMBERING_EQN
    ENTRY LOAD_BLOCK
    CONSTRUCTION STEP NO. : 7 / 38 STAGE NO : 3 STEP NO : 3
    ENTRY NUMBERING_EQN
    ENTRY LOAD_BLOCK
    CONSTRUCTION STEP NO. : 8 / 38 STAGE NO : 3 STEP NO : 4
    ENTRY NUMBERING_EQN
    ENTRY LOAD_BLOCK
    CONSTRUCTION STEP NO. : 9 / 38 STAGE NO : 3 STEP NO : 5
    ENTRY NUMBERING_EQN
    ENTRY LOAD_BLOCK
    CONSTRUCTION STEP NO. : 10 / 38 STAGE NO : 3 STEP NO : 6
    ENTRY NUMBERING_EQN
    ENTRY LOAD_BLOCK
    CONSTRUCTION STEP NO. : 11 / 38 STAGE NO : 3 STEP NO : 7
    ENTRY NUMBERING_EQN
    NRECOVERABLE ERROR, CODE = 602
    ERROR : WRITE_F , ERROR CODE= 1
    2015-11-22 08:47:22
MIDAS
5.84 万条内容 · 317 人订阅
midas Civil在桥梁结构分析中的应用 高清版哦
本帖最后由 wowo2199 于 2015-11-20 21:46 编辑 midas Civil在桥梁结构分析中的应用很实用的midas分析用书
