土木在线论坛 \ 给排水工程 \ 天正给排水 \ 飞扬~~~~7.5+2002问题。
飞扬~~~~7.5+2002问题。
发布于:2007-10-30 18:23:30 来自:给排水工程/天正给排水 [复制转发]
原来我用过6.0+2002,移动或者编辑文字的时候会出现致命错误(hztxt),昨天用2002+twt7.5出现了老问题,是不是也要到天正去下那个hztxt?我记的原来是怎么解决的,用2002的原因是转存r14方便。
全部回复(7 )
  • korterry
    korterry 沙发
    Summary of AutoCAD 2002 and AutoCAD LT 2002 Service Pack 1 Fixes
    General Issues
    A random crash that occurred when you switched between drawings has been resolved.
    The defunct Redspark icon and link have been removed from the standard AutoCAD dialog boxes.
    When an active viewport is set to Current, it is now highlighted.
    Tessellation of the edges of small 3D geometry features has been refined.
    Exploding proxy objects no longer result in duplicate text objects.
    OLE object frames no longer appear in layouts where they were not inserted.
    Markup text in a metric drawing is now scaled properly.
    Text window flashing no longer occurs when you list objects in a viewport located on a layer that is either frozen or off.
    Small arcs that are output to DWF format are no longer converted to circles.
    Handles are no longer renumbered when an AutoCAD Release 12 DXF file is read.
    Performing a transparent pan or zoom from the DTEXT command no longer results in a fatal error.
    The problem causing a randomly occurring license error has been resolved.
    Digitizer Issues
    The erroneous invocation of the Selection box when a tablet is calibrated has been fixed.
    A random cursor is no longer displayed when a Wintab driver is used.
    With certain digitizers, commands are no longer issued twice for every pick.
    The second button on a puck no longer issues random pick points in certain digitizers.
    Dimension Issues
    The ordinate dimension value no longer changes after panning in a viewport.
    Reassociated radial dimensions no longer display an incorrect value.
    Plotting Issues
    PostScript drivers no longer limit the available paper sizes.
    The Add-a-Plotter wizard no longer crashes when you use a PostScript driver and you select a 48-inch roll.
    Performance has improved when plotting to DWF drawings that contain nested xrefs.
    Issues Related to English Versions of AutoCAD Running on Non-English Operating Systems
    Certain non-English content on the Autodesk Today page can now be viewed correctly.
    The installation no longer stalls when specifying a double-byte folder name.
    Copying BIGFONT text no longer causes a fatal error.
    Double-byte share names in UNC paths are now recognized on client workstations and servers that contain the same locale settings.
    Open/Save Issues
    AutoCAD no longer crashes when you copy a layout containing an OLE object, perform an Undo, and then save the drawing.
    In certain situations, the Look In list is no longer blank in the Open dialog box.
    Hide Issues
    After using the HIDE command, you can now select a 3D solid edge.
    After using the HIDE command, you can now snap to dimension geometry.
    Snapping to dimension geometry after the HIDE command is issued no longer causes a fatal error.
    Dimensions no longer turn white after the HIDE command is issued.
    Xref Issues
    Binding certain xrefs no longer causes a system failure.
    An access violation no longer occurs when you perform reference editing on an xref that contains a VBA scri pt.
    Some drawings that have xrefs containing hatches no longer crash when closed.
    2007-11-02 22:27:02
  • korterry
    korterry 板凳
    autocad2002打上sp1就不会出现这个错误喇
    2007-11-02 22:21:02
天正给排水
6.48 万条内容 · 366 人订阅
天正的视口功能
天正同一张图可以分割几个窗口,以便观察细部,可以方便的对照户型,观看系统图窗口分割为2个
