土木在线论坛 \ 装修设计 \ 家装设计 \ Breukelen住宅/ Zecc Architects建筑事务所/House Breukelen / Zecc Architects
发布于:2015-09-30 20:53:30 来自:装修设计/家装设计 [复制转发]
自1760年起,一栋具有纪念意义的马车房附属马厩改建成了一栋宽敞的住宅建筑。以前整修的各种混搭元素也已移除,从而重塑了其历史元素和宽敞空间。马厩仍和干草架、石槽和铸铁马头放在一起,作为客厅。原来的马具室现在为入口大厅,而马车房则干成了宽敞的厨房。拆迁后又重新添加了一些高棚门。
A monumental coach house annex stables from 1760 is converted into a spacious house. A mishmash of built curiosities from previous renovations is removed. In this way the historical elements and large spaces return. The stable, still complete with hay racks, stone troughs and iron cast horse heads, is used as a living room. The original tack room is now the entrance hall and the coach house has been converted into a spacious kitchen. Some high stall doors reappeard after the demolition.
这造就了客厅和厨房之间惊人的连接。在此较高的室内尺寸,增建了一段新楼梯作为现代的添加品。楼梯位于马车房的中心位置,十分醒目。室外由镜面光滑粉粉刷,而室内则完全由橡树实木制成。由于是中心位置,也就成为了房子的枢纽,日光从屋顶照进新的厨房。楼上粗糙的木桁架双罩决定了气氛。楼梯还连接了第二客厅和壁炉。
This created a surprising connection between living room and kitchen. In this high inside dimension, a new stair is placed as a modern addition. The staircase has gotten special attention because of the central position in the coach house. The exterior is made of mirror smooth stucco and the interior is entirely made of solid oak. The central placement made it the hub of the house, daylight falls from the roof into the new kitchen. Upstairs the double hood with rough wooden trusses determines the atmosphere. The staircase creates a connection between the second living room with fireplace.
Floor Plan 楼层平面图
Section 截面图
  • phanghui
    phanghui 沙发
    不错,谢谢楼主的分享。。。。。。。
    2015-10-01 08:58:01
  • yuyanhui63
    yuyanhui63 板凳
    不错啊,谢谢分享!
    2015-10-01 05:17:01
家装设计
22.34 万条内容 · 391 人订阅
Nguyen住所/Atelier Moderno/Residence Nguyen / Atelier Moderno
在董事兼总裁Jean-Guy Chabauty (APDIQ, ADIQ)的指导下,工作室Moderno是一家提供全面服务的设计公司,提供成品,体现为合成建筑,室内设计和工业设计。这个项目的任务很简单,诚实——为正在准备组建家庭的年轻夫妇建造一个住所。回应促成了一个沉寂且宽敞的环境的发展,细化规划,建筑,和细节的每一个规模。房屋的地形和材料整体肯定了它自己,并把改变它的存在和影响作为家庭内部的一个循环。
